There have been a number of posts recently about the upcoming AMD 7xxx series cards on this forum and others so here is a round up of the details available from AMD and TSMC dated as of 16/10/2011. Im going to get into fine details on this thread for those interested but here is a roundup of what we know from those directly involved.
1)The cards will be made on a TSMC 28nm HP process.
2)There will be two Architecture types firstly VLIW4(very long instuction word) a die shrink and tesselation improvement over current cayman VLIW4 in the 6970 and secondly but more important the new GCN(Graphics core next) originally not planned to be introduced in this generation at all. It was roadmarked for 8xxx series and beyond. However the GCN is understood to be used in only the flagship models 7970 and 7950. This is a radical overhaul of the architecture and moves into massive gpu compute capabilities far beyond just being a gpu. Similar to what nvidia did with fermi and upcoming keplar. Ill link detailed slides from amd's june 16th talk on called upcoming architecture for a new era for those interested in a diagrams.
detailed anandtech roundup of GRAPICS CORE NEXT (GCN) link here
http://www.anandtech.com/show/4455/amds-graphics-core-next-preview-amd-architects-for-compute
fetch and simd details
http://www.nordichardware.com/image..._Islands/fullimages/AMD_Southern_Islands3.jpg
compute unit break down
http://www.nordichardware.com/image..._Islands/fullimages/AMD_Southern_Islands1.jpg
now the latest spec info for GCN cards
Graphics card Radeon HD 7970 Radeon HD 7950
Node TSMC 28nm HP TSMC 28nm HP
Architecture GCN GCN
GPU Tahiti XT Tahiti Pro
Radeon cluster 32 30
Radeon cores 2048 1920
GPU frequency 1000 MHz 900 MHz
Texture units 128 120
ROPs 64 64
Graphics memory 2GB XDR2 2GB XDR2
Memory freq 8000 MHz 7200 MHz
Memory inter 256 bit 256 bit
Memory bandwidth
256 GB/s 230 GB/s
Power consumption
190 watt 150 watt
and the die shrinked and tweaked compiler VLIW4
Graphics card Radeon HD 7870 Radeon HD 7850
Node TSMC 28nm HPL TSMC 28nm HPL
Architecture VLIW4 VLIW4
GPU Thames XT Thames Pro
Radeon cluster 24 22
Radeon cores 1536 1408
GPU frequency 950 MHz 850 MHz
Texture units 96 88
ROPs 32 32
Graphics memory 2GB GDDR5 2GB GDDR5
Memory frequency
5800 MHz 5200 MHz
Memory interface
256 bit 256 bit
Memory bandwidth
186 GB/s 166 GB/s
Power consumption
120 watt 90 watt
prices no public availabilty (suprise suprise)
now the noticable differences between the cards
1) The GCN has XDR2 memory at a staggering 8000MHz the VLIW4 rev b sothern islands uses gddr5 at 5800Mhz for reference current cayman 6970 is at gddr5 5500MHz.
2) According to the amd slides shown above at AMD june 16th talk the GCN(Graphics core next) will handle x86 code and virtual memory as well as full support for any c++ construct including dlls and virtual functions this opens up a whole new bag for developers to use with the bounus that they already code in this way.A lot of applications can be easily patched or coded in very simple ways to use the full power available of the gpu compute on the GCN. This is a radical break from the more specific gpu accelarated tasks currently available on VLIW4 and fermi/keplar platforms.
3) The power footprint is reduced considerably during the die shrink. The 7870 which is a revision of the caymen 6970 core uses less than half the power coming in at a lowly 120 watt compared to the 250 watt of the 6970.
The top end 7970 uses 190 watt still a lot lower than the current cards.
My thoughts
This is the currently available information from AMD and TSMC on the 7xxx series gpu's. I fully expect things to change from now until launch but not greatly from what we see here. That being said it looks like due to fast turnaround of nvidia from its 4 to 5 series and upcoming keplar Q2/Q3 2012 AMD has had to bring forward its GCN to this generation. Perfomance can only be estimated so I wont even go into that until we have benchmarks, but the sweet spot looks like the 7950 GCN for the all round performance plus gpu compute. or for the budget gamer even crossfire 2x 7870 with a power req of 10 watts less than a single 6970 similar at least and if not better performance than a 6990 at a fraction of the estimated cost and will run on a lowly powersupply.
I just wanted to share the current information and hear your thoughts on these cards and the direction of gpu's according to AMD plans.
look forward to reading your comments and thoughts.
ps no flaming I love the green team as well
cant wait to see what they bring to counter this move by AMD interesting time for GPU's
ROPs 64 64
Memory bandwidth
256 GB/s 230 GB/s
Power consumption
190 watt 150 watt
Texture units 96 88
ROPs 32 32
Memory frequency
5800 MHz 5200 MHz
Memory interface
256 bit 256 bit
Memory bandwidth
186 GB/s 166 GB/s
Power consumption
120 watt 90 watt
My thoughts
