1090T or i5 2500k?
The 95w 1055Twill work in your board, but I would go for thePhenom II X4 Quad Core 850 "95W Edition" if it's for games as it's about £40 cheaper.
Don't think it's a good idea to go the "Phenom II" X4 850, as it is bascially just a Athlon II X4 under the Phenom II X4 badge in reality without the L3 cache.
I highly recommend going for the i5 2500K, much better CPU, runs cooler, a lot less power consumption etc.
Most cost-efficient upgrade is to a Phenom II X4 955 BE (since it doesn't require a new motherboard). However, the i5-2500K is the best all-round gaming CPU right now.
Will a 125w cpu work in a 95w supported board?
The i5 is the best all round chip yes, but is the extra £200 cost over an amd chip worth it to the op?
I wouldn't invest more money on a low-end board like the ASRock N68s-ucc...it doesn't even have a AMD chipset on it.
I would just take this opportunity and move onto the 2500K...
Sorry to thread-jack... but..
Phase 1: change mobo
Phase 2: phone MS automated activation hotline
Phase 3: get new activation code
Phase 4: ???
Phase 5: Profit.
really? I thought that you couldn't change your mobo with an OEM windows?
If so, I'll be calling MS this week.
Tell them your system broke due to a power surge and you couldn't replace the parts as you couldn't buy them any more, they'll probably activate it again.
