- 20 Jun 2011
- Livingston
Will this stuff dye and gunk up the inside of my loop / blocks?
with the clear one, can you add any colours to it?
because I am a doubleposting noob
mlwood has confirmed that his dyes are 100% compatible with these fluids
the dyes will be listed soon![]()
Were doing some major changes to Mayhem's Atm. So right at this moment in time its Pointless for OCUK to buy in dyes until the changes are complete. Rome wasn't built in a day.
you can have the green mayhems dye that I have cleeecooo![]()
you two are like husband and wife!
Think I will join Richard withusing tharsis red - looks great, but not sure if it will work with the EK dcp 4.0 with tube res????
Mark
I blame kii. He always has to gay everything up
should work fine with it
I think it works best with tube res'?
EK DCP 4.0 800lph is the same as Phobya pumps so it will work fine with no problems.
We tested the 400 Ltr of these pumps ad they had good over head pressure and worked really well.
@Cleeecooo low end pumps don't work well and any thing with low over head pressure such as those used in the XSPC Res/Pump combos and any thing below 400 Lph.
because I am a noob![]()
