- 5 Nov 2004
http://www.engadget.com/2011/10/18/canon-announces-eos-1d-x-full-frame-18mp-sensor-14-fps-204-80/
The EOS-1D X combines speed with image quality, to create the next generation camera for professionals. Full frame 18 megapixel sensor with Dual “DIGIC 5+” processors sets the standard, and up to 12 frames per second shooting takes it beyond.
Features
18.1 MP full frame CMOS sensor
Up to 12fps plus 14fps High speed mode
100-51200 ISO, up to H:204800
61 point AF system
100,000 pixel RGB AE metering
Full HD 1080p EOS movie
Clear View II 8.11 cm (3.2”) 1,040k LCD
Ethernet port
Performance redefined
A Canon 18.1 MP full frame CMOS sensor delivers stunning performance, producing exceptional low noise, high-resolution images even in the darkest conditions. The full frame sensor delivers optimum results from wide-angle lenses and gives you greater control over depth of field. Image resolution exceeds the quality demanded by leading photo agencies - making it ideal for extra large prints up to A2 size, even after cropping.
Super high speed shooting
Capture every second of the action with up to 12fps continuous shooting, increasing to an incredible 14fps in Super High speed shooting with continuous bursts of up to 120 large JPEG images (36 RAW).
Huge ISO range
An exceptionally wide ISO range of 100 to 51200 – expandable up to an incredible ISO 204800 – means shooting need never stop from the brightest conditions right through to near darkness.
61 point AF system
A high-precision 61 point AF system, featuring 41 high sensitivity cross type sensors, delivers fast, accurate focussing of fast moving subjects – whatever the lighting conditions. The centre 5 AF points are dual cross type for added precision.
Consistent, accurate metering
A 100,000 pixel RGB AE metering system with a dedicated DIGIC 4 processor measures not only brightness but also colour to ensure highly accurate exposure for natural results even in complex lighting situations.
Full HD EOS movies
Shoot Full HD (1080p) video with a wide range of user selectable controls on a DSLR including exposure, frame rates, audio and compression control. An HDMI output allows High Definition playback of footage and images.
Canon’s latest generation Dual “DIGIC 5+” processors deliver the fastest and most advanced image processing to date for best-in-class image quality. Working with 4 A/D converters to provide 14-bit image processing for smooth tonal gradations and natural looking colours as well as advanced Noise Reduction at higher ISO speeds.
Large, anti-reflective LCD
A high-resolution 1,040k-dot 3.2” Clear View II LCD screen, allows easy, accurate review of images and video. Superbly durable, an anti-reflective, hardened glass structure prevents reflections even in the brightest sunlight.
Ethernet port
A built in Ethernet port allows for fast, easy transfer of images directly to a PC or via a network to clients from live events.
Features
61 point AF system
Ethernet port
Huge ISO range
61 point AF system
Full HD EOS movies
Ethernet port
