- 11 May 2006
Then just get the HD650. As I said, the Essence STX should be fine, so long as you set the gain correctly (I use +12db).
Amps can have a subtle effect on sound.
i went teh dac / headphone amp route .......mf v-dac / graham slee solo srg11 cant fault the combo for music ... and pretty good for gaming
Amps can have a huge effect on sound. Using my valve amp with my D2000s renders them too bassy to live with. However, with my Shanling PH100, they are brilliant. My HD 650s sound great through either, but really come to life on valves with much improved bass response and impact, almost to the level of the D2000s on the PH100.
The HD 650s are simply bloody brilliant, and HD 595s pale in comparison IMO. They will sound less bright, but you should grow to love them. They're so detailed, and at the same time very easy to listen to.
The HD650s don't need equalising. Anything that doesn't sound 'right' will quickly be accounted for by your brain, which is pretty much an equaliser in it's own right.
Mate I am sorry but this full post proves you dont know what you are talking about.
You are not trying to hear a flat sound you equalise to reduce resonant peaking frequencies that are there FACT!
How much and at exactly what frequencies depends on the cans an your ears but they are there!!
It's easy to think something is sounding right- it's only when you hear that it's clearly not right then you realise you are wrong!
HOWEVER regardless when linkwitz Riley who has designed more audio circuitry used today than you have had hot dinners says something then you should listen.
I thought the same as you until 2 weeks ago - very wrong I was!
!!I can only trust my own hearing, and I have no idea what you're talking about with regards to these 'resonant' frequencies. The HD650 sounds pretty much perfect to me in terms of frequency balance. Have you actually heard the HD650? I'd probably agree with you if it was say, my Audio Technica ATH-A900, but not the HD650.
But, if as you say, the HD650 does have these 'peaking frequencies', then I'm guessing they are a desirable characteristic in headphones. This is the consensus of most audiophiles I know of, not just my own opinion.
I don't recall anybody saying the 650s were flat.
