Today we have the Krypton Z68 600i Intel Core i5 2500K bundle which is perfect for jumping into the next generation of computer gaming. the Intel 2500k is a fantastic chip which has great overclocking abilities. Build and tested by our professional technical staff, you wouldn't be disappointed with this bundle.
We also have Corsair Vengeance 8GB DDR3 memory at the best price in the UK and with a full time warranty, it's the perfect upgrade if you want to have your computer perform better in multitasking and other applications.
Krypton Z68 600i Intel Core i5 2500K 3.30GHz @ 4.60GHz Overclocked Bundle @ £392.96 inc VAT
Designed by experts the "Krypton Z68 600i Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.60GHz overclock has the processing power and speed unseen at this price point ever before. The "Krypton Z68 600i" will accelerate your computer experience into the next level.
Why You Should Buy This Bundle?
- A solid, optimised 4.60GHz overclock profile provides outstanding processing performance
- Prebuilt, overclocked and configured. Just "plug and play"
- 8 Hours stressed tested and quality controlled
- 4GB of Dual Channel DDR3 memory delivers unsurpassed bandwidth
- USB3, SATA 6GB/s, Intel Ethernet and EUFI graphical BIOS for next gen computing
Bundle Specification
- CPU: Intel Core i5 2500K 3.30GHz @ 4.60GHz Sandybridge CPU
- Motherboard: Asus P8Z68-V Intel Z68 (default choice)
- RAM: Kingston HyperX Genesis Grey 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel
- Cooler: Corsair A50 CPU Cooler
- Artic Silver 5 Thermal Compound
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Note - Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Only £392.96 inc VAT.
ORDER NOW
Corsair Vengeance 8GB (2x4GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (CMZ8GX3M2A1600C8) @ £50.39 inc VAT
CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1600MHz 8-8-8-24, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each two module set is tested at 1600MHz
- Vengeance heat spreader for styling and performance
- Packaged together immediately following system test
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 8-8-8-24 on Intel DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 8-8-8-24 values at 1600MHz, 1.50V
- 8192 Megabytes of DDR3 memory
- Two matched 4GB modules
- 100% tested at 1600MHz in Intel based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
- Sandybridge compatible
Only £50.39 inc VAT.
ORDER NOW
Service Package
ORDER NOW
- Lifetime Warranty
ORDER NOW
