Occupy London! Here we go again!
So much for the "“All day, all week, we’ll sleep on London’s freezing streets” posters. Only one thing to do now, clear the scum tents at night if they're empty.
Thermal Image camera only records surface Temperatures, it's not an X-Ray camera that can see all the people inside their insulated tents, probably inside their insulated sleeping bags...
Jumping to conclusions != pointing out holes in logic/offering alternative options ;)
Dolph, i'm still waiting for you to reply to Floogie's post properly :p
Don't confuse you not liking the reply with a lack of reply.
Every capitialist democracy is the west does disprove the idea of a 'dictatorship of the bourgeoisie'. Just because people don't vote for what you think they should (mainly because many of them are old enough to remember communism in action) doesn't make it a dictatorship.
Secondly, in a free and liberal society, there have to be sufficient protections to prevent any group of people infringing on the rights of others without a need to do so, hence constitutional protection.
Those are the answers to Floogie's questions, sorry if they aren't simple enough answers to allow the loaded question fallacy attempted to continue ;)
So you admit that your responses are often loaded? Since all he did was throw it straight back at you.
I guess we can see the truth now though, that in a real life situation you would be just as authoritarian as those that you despise.
guaranteeing rights that do not require infringement of the rights of others can never be considered authoritarian.
I thank you for the weasel words. So we see that a libertarian capitalist regime would have a constitution that would have to be enforced by authoritarian means upon its citizens should 'enough' people choose to break away or overturn it.
At least in theory a libertarian socialist society would require minimum authoritarian rule as the majority benefit from it. A libertarian capitalist society doesn't even have that going for it.
So who's the dreamer now?
Using force to act against the will of the masses on the other hand...
technically it is using force to protect the rights of individuals against the mob. authoritarian states act against the rights of individuals, as in socialism/communism.
presumably you'd be happy for skin colour based lynchings to go ahead if the majority supported it...
you are confusing having laws with authoriarianism.
I'm buying those tents and covering the house in them. Will massively reduce my gas bills. Who needs expensive insulation a meter or so thick. When a bit of cloth is even better.
And lol at the forced comments. How can you even think it would be less or non existent.
Only one way to find out, the bulldozer!
lol @ insulated tents.
Well, if the Tents are not insulating against the Thermal Camera, can you explain the floating in mid-air Half-Man and the floating in mid-air head and shoulders from the same Camera here:
I think it is due to the insulating properties of the Tents, you know they have a double-skin right? the outer one will be cold and not show up on Thermal imaging, but hey I look forwards to your explanation :)
