Battlefield 3 thread - Server details in opening post -
Status
Not open for further replies.
Ok further issues now, I right clicked on the battlefield tile in origin and clicked repair, it downloaded an update but now it is saying it is uninstalled and it wont install it.
The folder is on my pc and is the same size as before 11.4gb but origin wont re install it?
cool, well it seems i cant play this game untill its fixed. constant CTD or you have been disconnected from the server every 2 minutes.. great..
Have you tried disabling UPnP in your router settings?
I had constant DC's in Bad Company 2 with it on, i thought BF3 might have been different so turned it back on only to find out that with it off i never get DC'd unless the server goes down.
I've had this problem. Have a look back a few pages for the solution.
Anyone know what wrong with this **** called origin ripoff. I get the game, install into my account, update my drivers and then restart the computer. I then try and start the game but I cant login even though I am putting in the correct password (getting incorrect details error). I then click on forget password and it says it will send the validation key but I am not getting anything on my email.
So I bough this game yet I cant seem to login and its not sending me any validation key to my email to reset my password. WTF is going on?
CrazyCanukk said: said:
Cheers to Apocalyptic to alerting me to this..
Gameservers is showing a server update scheduled for release in 2 hours aprox EST that is going out..
http://forums.gameservers.com/viewtopic.php?f=9&t=46618
Patch level R5 has been scheduled to be pushed onto all servers starting at 11:00 am EST
Changelogs
- Crashfixes
- Player slot issues
- Latest PunkBuster DLLs included (in case the server doesn’t auto-update)
- Security updates
- Fixed some problems with client<->server handshake, which would make players get kicked from the server halfway through loading
The big change on this one besides some crash fixes and the player slot issues is the PB update that the server will have and one of the reasons why this is a mandatory patch that must be applied to all servers. For the current version, PB versions between players and the servers have been almost a guessing game. So, for this patch and hopefully going forward, the latest PB is on the server. What this also means is that players will need to make sure that they have the latest version of PB installed for their game client install.
Daniel Mastros wrote up instructions on how to make sure you are on the latest version of PB.
Manually updating Punkbuster *recommended*
Quote:
By: zh1nt0 Posted: 3 hours ago 190 comments
For players that are having problems with not being able to connect, you probably want to take a look at this post.
To Manually update your local PunkBuster Security Files, choose "Save As" from your Web Browser's "File" Menu and explore to find your game folder and the subfolder called "pb".
Save this file in that location (/pb/pbsec.htm or /pb/pbsecsv.htm). The next time you start your game, your PunkBuster will have the latest security information necessary to accept auto-updates from PB Servers.
http://www.evenbalance.com/index.php?page=dl-bf3.php [evenbalance.com]
origina link is found on : http://battlelog.battlefield.com/bf3/news/view/2832654773952043053/
Ok i turned of Upnp, i think thats fixed the dc'ed but the game still doesnt feel smooth, It keeps gittering :(
I change my clock speed and did all those settings, still the same.
Everyone that has had their copy from Amazon delivered.... I HATE YOU*.
*not really I'm just grumpy that my copy STILL hasn't been dispatched
:D
Harry potter!
Status
