If it was Switz and converted at present exchange rate it's basically meaningless. I just got back and, although it's not as bad as the summer, it's still multiples more expensive to live in than the UK without a corresponding increase in service/good quality.
That is very true, it's where I live
though go over to France or Germany and things are much more reasonable!
I am a SharePoint Consultant, work on contract. I devoted a lot of time outside of work initially to learning new things and getting better, knew that it would pay off, and it has. As mentioned, been in IT for only 3yrs (that's including starting at the bottom rung of the ladder back then).
I put in the hours at home to bring myself up to speed on what I liked, trained hard. Got my MCITP EA within my first year in IT, liked SharePoint. Got involved in one project while in support, led to my next job... worked up from there. Hit the books and played a lot in spare time. I have the confidence and can pull it off. I can sell myself and have a good enough base now to back it up.
I believe that nothing is out of your reach and I am determined to get to the top in everything I do. I'm not even sure I want to work in IT, but you know, while I'm here I will make it to the top.
I used to be in a totally different industry, went from 18k at 20 to 31k at 22. Then the company I was with went down the pan, it was badly run, should have seen it, but that was in the 2008 "crash" and I was out of work 6 months. Decided I wanted to be in IT, thought everyone needs it. Started from there and have got to where I am now.
You want it, go and get it. That's all there is to it.
