So basically, My mate bought Acer 5742G with i5 480M CPU and nVidia 540M GPU.
Intel HD Graphics drivers install perfectly fine.
However, NO DRIVERS work for the 540M. I've tried countless combinations of intel+nvidia drivers and every time the nvidia gpu gets "Windows has stopped this device because it has reported problems. (Code 43)" in the device manager.
Also if I try to open the nVidia Control Panel, it gives error which says something like "cannot open control panel because the gpu is not bla bla something
(forgot it and my mate went to sleep so i cant check (using teamviewer for doing everything on his laptop))"
Updated the Acer BIOS as well.
Laptop is running Windows 7 Professional SP1 x64.
Any help will be much appreciated. If we can't fix it by monday, he (my friend) will call the retailer for repair/replacement.
Thanks in advance!
(forgot it and my mate went to sleep so i cant check (using teamviewer for doing everything on his laptop))"Updated the Acer BIOS as well.
Thanks in advance!
