Those using a Asus Xonar Soundcard should turn off their GX/DX settings in the Audio console software to prevent crashes.
The basic theme is around spammable explosion muntions, i.e. RPG/Mortar/M203.
THe few things which I can account for:
I play with flatmate who was kicked using the mortar, Though I told him he would probably be kicked. No issues there with him getting kicked, after it is announced that mortars aren't to be used... few maps later a TFU guy is using one.
Threatened with getting banned because I cleared a room of people with RPG and hit one of your guys as he ran in... I'd understand if I was spamming it, however he was just peeved at getting TK'd.
Then on the receiving end of M203's which doesn't bother me as it is all part of the game. But it is more or less in the same bracket as the RPG.
I'm Helier ingame btw.
Just how bad are these Mortars?
I don't like this inifinite ammo malarky, support is there for a reason, engineers could provide vehicles with ammo as well, i reckon it would make the game a lot better.
Thanks for that info, its always good for me to hear these things outside of TFU.
We don’t actually have a rule against using mortars, nor would i wont to limited items that DICE have put in the game. However if someone is constantly spamming them and doesn’t seem to use anything else then we’ll warn a few times and then kick. If a member or admin threatened to ban you then like anyone who uses our server you can report them on our forums under “admin abuse section” and I’l take the necessary steps. All we want to do is give people a server which is fair and not make them rage quit
I for one use the RPG’s, I don’t spam it, however if there is a room full of people then too right I’l use the RPG!!
They are pretty bad tbh.
The worst case scenario is.. Conquest, your on the losing side and you've been pushed back to your main base.. Everytime you spawn you try to find a new exit path but that doesn't work.
All the time, your on the receiving end of about 4 people who as using mortars and sending them directly to your base which means your lucky if you don't spawn and instantly die. You can't kill them because you can't escape from your base and you can't return fire because as soon as you set up you die from their incoming rounds.
It's not a bad weapon, it's just not 'balanced' yet. You should be limited to a number of rounds, range is fine if rounds are limited. I don't see any reason why you'd need to mortar a teams main base either.
people then suck to counter them.
or they like to camp, move around then they are a no issue.
server admins that limit weapons basically just suck at the game and should go play mw3.
