*** Pinguy OS ***
27 Oct 2006
London
Absolutely love this Ubuntu derivative, the developer has done an amazing job.
In a nutshell it's Ubuntu 11.04 heavily customised with a mint menu + osx look feel compositing. Lovely jubbly
http://www.techdrivein.com/2010/12/pinguy-os-probably-best-ubuntu.html
I'm a convert and love it to bits.
Check out this linux newb who has taken to it like fish to water, it's interesting watching his journey as new linux user - using what is a relatively powerful distro
Just spotted his Pinguy OS Howto Videos
I'm using pingEEE as it's more lightweight for netbook users. Anyone else a pinguy user ? It needs more love :)
I gave Pinguy a try but found it too crowded and full of stuff personally. If I recall correctly it had used about 7-8GB on my root partition. I was especially turned off by the way Firefox comes loaded up with a ton of extensions I didn't want. I figured that if I find myself having to remove a bunch of stuff to get it the way I like, then I'm probably better off just using Mint and adding the bits I like.
The other problem was that I tried running an old Windows game with wine and it always crashed while loading in Pinguy. Yet it just works without any problem on fresh installs of Mint. I never did work out what it was in Pinguy that the game didn't like.
Very good points NuclearWinter which to a degree I agree with. It swings both ways ... the bloat may be useful to those who don't have the time to check out packages, ie cherry picked.
It's probably the reason why I ended up installing pingeee on my notebook
thanks for this Sub! :)
I think I'm going to give this a whirl when I've rebuilt/replaced my No. 2 rig.
Looks like a ideal Ubuntu based starter/learning distro. This guy seems to run it all on a low/medium spec lappy as well!!
EDIT
BTW They've just released the 11.10 alpha with gnome 3 shell
looks like pre Alpha so it's very rough at the mo :)
Yeah I've taken it for a spin and it's not bad considering at least it gives you a taste for gnome shell but is slightly laggy for my liking so I'm back to 11.04 and its compiz goodness.
Apparently the developer wan't to bundle MATE not gs3 for that release so it could change an awful lot.
Good luck on 11.04 :D
MATE = Gnome 2 fork ?
No being smart :( ....... I had to Google it to find out what the hell it was.
Does not surprise me.. the dev seems to like his compiz and emerald goodness :)
I first used compiz/beryl around 5 years back when all I thought of it was 'eye candy'. Having been reintroduced to it I'm finding my desktop to be way more productive than I had anticipated.
Who needs gnome shell when you can get the same result by ....
Ctrl-Super by default opens the mint menu and I can search for whatever I like
Remapped the Windows (Super) key to scale all open apps :)
gconftool-2 --set /apps/compizconfig/profiles/Default/plugins/scale/allscreens/options/initiate_all_key --type string Super_L
gconftool-2 --set /apps/compiz/plugins/scale/allscreens/options/initiate_all_key --type string Super_L
Scaling plugin to highlight, close and move windows - I'll put up a youtube video if there's not one up there already...
But you're right - old gtk2 themes but wth it works and works REALLY well :)
I have been using Pinguy for a while now and really like it.
The only problem I encountered was Conky would not go into the background when I loaded a program and hid the Max/Min/Close buttons, but a quick post on the Pinguy forum produced the answer.
Although I have been using Linux on and off for about 6 years, I would recommend any one coming from Windows to Linux to try Pinguy.
after using a few distros at work, mostly ubuntu derivatives, I've finally settled on pinguy. I've removed all of the htpc stuff, but for someone who just need a windows replacement that works out of the box it's a fantastic OS :)
