If you crack on with patching to a centralised location it will make your work seem a lot easier.
Any one with CCNA should be capable of setting up such a simple network, check Gumtree.
Will check on Gumtree, thanks for the help.
Couldn't you get 2 100mbps lines from Virgin or something, then assign 12 flats to 1 line and 13 to another?
By "25 flats" I assumed 25 flats each with a few people in them. If it's 25 single flats then 100 Mbps is probably fine.50mbps / 100mbps between 25 or 40 people is better then nothing. Internet in university halls is very bad at most places, do they care when you complain? No. My university halls was something like 100mbps between hundreds, it served purpose for research and some downloading (which by the way was all blocked) anything else was just not possible...e.g. Games etc.
