PS3 Position
30 Nov 2007
Does it in anyway make any difference which way you have your PS3 ?
Standing or lying flat ?
i find with the slim ps3 it looks like it might be a bit unsteady on its side? , ive never tried it as i have mine flat.
Can the slim do both, like the phat?
Goes twice as fast if it's standing up.
Seriously, what difference did you think it would make? Do you honestly think they would design it to sit two different ways if one adversely affected the machine?
The OP probably wondered if the cooling was better in one position over the other. Whatever the case it would only be a couple of centigrade at the very most so it's not even worth considering. As you say, it would have to be a pretty poor piece of hardware if it worked brilliantly in one position but terribly in another.
nail on the head
thanks for input guys
