Battlefield 3 thread - Server details in opening post -
Status
Not open for further replies.
Looks good, any other contenders? If not, I'll take the plunge!
Well i've heard the Rocat Kaves are quite good although none of my friends have one and i've heard This one is quite good, although again no friends that have and only one review on that link.
They are both a little over budget, compared to the original one i linked.
I wonder if 4GB of DDR2 and a Q6600 would do me? I can probably buy a G0 that'll do 3.4 on air if I'm picky...
I have 4GB of DDR2 and a Q6600 @ 2.4Ghz. Graphics card is a 6870HD. The graphics options are on auto (basically everything is set to high) and the game runs very smoothly and looks excellent. I dont know what my FPS is, but all I can say is I dont notice any slow down or jittering.
The only time I have ever had an FPS drop enough to notice was occasioanlly on Caspian border. However, even there it's only jsut enough to notice, so it;s probably dropping to the 30-25FPS range. But it's still absolutely playable and not a problem.
I guess you'll be fine, this engine really is very well optimised.
Mine does this also, tried every fix going, funny thing was I managed a few rounds before it went like this. Reinstalled windows, game, drivers, bios, tried different hardware. Tried the live chat and got told a reboot would fix it - I may have given the chappy a bit of grief. Got to another person and he just said to wait for imminent patch. While I wait I may just buy that rival title... hmmm.
Since i swapped to these ati drivers on guru3d all my crashes have gone away i used to get the bf3.exe has stopped responding and black screen problems with the 11.10 whql so gave these a try and all the problems went
http://forums.guru3d.com/showthread.php?t=353416 word of warning for xfire users they are supposed to be bad for that according to the posts on there.
Give them a try nowt lose :p
I agree. On conquest, the only front line I find is at choke points on metro or the alley on bazaar for example. They aren't fun front lines to be caught up in either as you always get nailed by an RPG.
doesnt help that the maps are so small... they seem tiny when your in a jet or a heli compared to even the old bf 1942 maps some of them wrere so huge it took you awell over a minute to get from your base to the enemy base.....
i could murder for some classic bf1942 desert maps
Just ordered my new pc so i'm closer to being able to play this. Don't suppose anyone knows if it will be coming to Steam after all?
Sorry, figured this was the best place to ask this.
I spent last night practicing in the jets and helicopters and now think that the jets are kind of pointless as they are just now. Unless I've not unlocked it, they don't have a decent air to ground weapon and the only real use for them is to take out other jets or helicopters.
The helicopters do the same as the jets but do it all better. Plus they are good for attacking ground targets and capturing flags.
My advice would be to train helicopters first. If you want to unlock flares and missiles early, go on an emptyish caspian border server and use it to capture a couple of flags. At 250 points per flag I think you only need 3 flags and you'll get them both.
Sorry to tell you but... the main cannon is THE only decent weapon on the jet.
It can disable tanks/AA/choppers/jets in one pass (albeit a slow one for tanks). Rocket pods are soo weak it makes you wonder if it is just there to switch to whilst your cannon reloads. Heat seekers are next to useless when people have stealth and flares.
Ordered, thanks. That's a cracking deal...though I hope the 4-6 week quoted dispatch is a mistake!
Got the dispatch confirmation from Tesco Entertainment today, so 4-6 weeks was indeed bs :cool:.
Looking forward to this, though I strongly suspect it'll need an expensive upgrade to keep me happy!
I haven't played BF2 for so long that I had forgot that there was the spec ops classes in an expansion that had zip lines which I remember using on some map with a Mosque. Makes me wonder what other awesome stuff I have forgotten about.
Grappling hooks
Quad Bikes
Driving Civilian Cars
Jet Skis
Gas Grenade launcher
:D
I generally use the rocket pods when the canon reloads. They do enough damage to finish off a vehicle after you reload. There's an AGM you can unlock later I believe, haven't tried it though.
I think the best unlock is the fire extinguisher. It helps against bullets as well as heat seakers and has a pretty quick reload time.
Not trying to troll here or be insensitive or anything, but what rubbish.
If you think the Heatseakers are next-to-useless then you'redoingitwrong.jpg, plain and simple. I have no problems whatsoever using Heatseakers against jets that have both Stealth and Flares - you just need to know when to fire. If you're right up close behind them you can pop both missiles and they should still hit even through flares, but you have to be very close for this to work. Any other range, get a lock and fire one missile. By the time they've flared off and you've reacquired the lock, assuming you're a competent pilot and can actually keep them within your reticule, your second missile should be back and you can fire both off for a double hit before their flares have regenerated.
Even if you can only get one hit with a Heatseaker, it's then only two or three hits from the chain gun and that jet is going down.
The rocket pods rip through armour so long as you're accurate with them - and they do like to spread around a bit from what I've seen so far - so they are a bit harder to get used to. Personally I would favour the chain gun over the rockets unless it's a jeep or infantry you're shooting at.
The Guided Missile is appauling to use when you first get it. It takes a long time to lock on to vehicles, through which you have to be flying fairly high to begin with, and then fly fairly straight to get the lock, and then eventually fire a missile down - all the while you're looking at a screen rather than around your cockpit, leaving you open to free fire from enemy anti-air capabilties.
However, and this is a big however, one you unlock Beam-Scanning, the world changes. Lock-ons to other jets take next to no time at all, to the extent that someone can flare off and I will have them locked again two seconds later. This applies to the guided missile as well. This locks on a lot quicker making it quite a useful tool on ground vehicle-heavy maps like Kharg Island and Operation Firestorm.
As I said to begin with, not trying to be harsh or hurtful, but it's down to user error from where I'm standing :p
Tactical light is getting hit by the nerf bat.
Before:
After:
Demize tweeted it.
Are there servers dedicated to heli/jet praccy? Trying to fly with a mouse is ridiculous! Ive got a 360 controller, need to map it a bit better than standard though!
I'm running:
Q9550 @ 3.46
4GB DDR2
Crossfire 6970
Gaming at 2560x1440 and seeing 40-70fps on ultra settings. It seems pretty smooth to me, I think the CPU and RAM is plenty. I'll try disabling Aero late and see if that makes any difference :)
Not really. Your best bet is to try and get on a Conquest server with very few players on and hop in a jet to get to grips with it.
I still stand by my mouse + keyborad. Pads and joysticks feel wrong on BF3 for me.
On a slightly related note, I love the AH-1Z Viper with the mouse - can fling it absolutely everywhere, I love it, it's so versatile! The Havoc on the other hand is like trying to move a block of flats through cement in comparison!
I think a few people from here have been in the Viper when I've been flying it on TFU - in-game name Benneh1 - and seem happy with it :D
different game different time, slow ass transports.
Demize tweeted it.
annoying things gets fixed, I flash my teammates more than the enemy and I am not even naked..
1. fix the bugs 10 years to do for dice with their trackrecord. Bf6 be out then
2. hitreg and the assist aim for noobs likely never be fixed since its part of gamedesign. lower dmg with 8% and the game would work much better.
the anoying design and the bugs makes the game likely the most issue ridden frustrating game of all times.:)
Status
