** AMAZING GRAPHICS DEALS - GET BF3, DIRT3, DEUS EX & BATMAN FREE WITH QUALIFYING CARDS! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
OK got some truly epic game bundles with qualifying graphics cards at present so check these out:-
Asus ATI Radeon HD 6950 DirectCU II 2048MB GDDR5 PCI-Express Graphics Card **Supplied with Battlefield 3 & Deus Ex PC Games** @ £239.99 inc VAT
The ATI Radeon HD 6900 series features the latest graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, new AA and image filtering options, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a.
Features:-
- Speed up heat dissipation with 600% more airflow via exclusive DirectCU with dual fan design
- Expand your visual horizon across six monitors with four native DisplayPort outputs
- Super Alloy Power technology delivers 15% Performance boost, 2.5 longer lifespan, 35C cooler operation
- Crank up 50% faster clock speed with exclusive Voltage Tweak
- Core Clock: 810MHz
- Memory: 2048MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Bandwidth: ??GB/sec
- Processing Cores: 1408
- Texture Units: 88
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 1 Dual Link DVI-I and 1 single link DVI-D, 4x DisplayPorts
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Maximum Power Consumption: 250W (Typical 190W)
- 1x 6pin & 1x 8pin PCI-E power connectors required
- 450W minimum PSU recommended
- Warranty: 3 Years
- Supplied with FREE Deus Ex and Battlefield 3 PC Games
Only £239.99 inc VAT.
ORDER NOW
HIS ATI Radeon HD 6950 IceQ X PLUS Edition 2048MB GDDR5 PCI-Express Graphics Card **Supplied with Battlefield 3, Dirt 3 & Deus Ex PC Games** @ £239.99 inc VAT
Features:-
- Special IceQ Cooler taken from 6970 and custom fitted to 6950 by HIS for upto 18c better cooling
- Great OC Potential
- OcUK Exclusive
- Core Clock: 800MHz
- Texture Units: 88
- ROPS: 32
- Display Connectors: 1 Dual Link DVI-I and 1 single link DVI-D, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- ATI Avivo HD
- 2x 6pin PCI-E power connectors required (Power Adapters included in box for older PSU's)
- Warranty: 2 Years
- Supplied with Battlefield 3, Dirt 3 and Deus Ex PC Games
ORDER NOW
MSI ATI Radeon HD 6970 Lightning 2048MB GDDR5 PCI-Express Graphics Card **Supplied with Battlefield 3 & Deus Ex PC Games** @ £299.99 inc VAT
nonl2br
<img src="http://marketing-uk.msi.com/images/AMDLightningStatic.jpg" alt="MSI Lightning" /><br>
<br>
These cards are specifically designed to handle the extreme overclocking which eager gamers and media outlets around the world have been waiting for. Industry-leading Power4 architecture and Twin Frozr III dual-fan cooling with innovative Propeller Blade technology brings together a solid power supply with advanced cooling technology. This results in huge boosts to overclocking potential and stability, enabling the air-cooled 6970 Lightning to break the 1GHz core clock barrier with ease. The Lightning series of graphic cards is designed to offer the ultimate in overclocking capabilities and is the superior choice for overclocking enthusiasts seeking to set new world records! <br>
<br>
<Font size="5"><b>Key Features</b></font><br>
<br>
<img src="http://marketing-uk.msi.com/images/power4.png" width="210" align="left" alt="power4" /><b>Industry-leading Power4 Architecture for Overclocking Reliability</b><br>
Inheriting the impressive Power4 architecture from previous Lightning cards along with improved components and design in four areas. The PWM module is twice as large as before and provides double the amount of current to the GPU. Memory has its own independent power supply using an 8-pin connector for minimum interference to greatly increase overclocking potential. The next-generation Proadlizer capacitor increases signal stability by leaps and bounds while CopperMOS, the industry's best MOSFET, provides the GPU with a large and stable power supply. Combined, these features provide ordinary users as well as extreme overclocking enthusiasts with a more stable operating environment and the best performance out there. <br>
<br>
<img src="http://marketing-uk.msi.com/images/lightningsplit.png" width="210" align="right" alt="Cooling" />
<br>
<b>Twin Frozr III and Propeller Blade Technology Takes Cooling to the Next Level</b><br>
The all new Twin Frozr III cooling design utilizes the innovative Propeller Blade technology to double the amount of airflow compared to conventional fans. The airflow also covers a large surface to remove heat quickly and effectively, and when you add in twin 9cm PWM fans, SuperPipe technology, and the Form-in-one heatsink, the result is GPU operating temperatures 26°C lower than the reference board when the 6970 Lightning are operating under full loads. Fan noise is also 11dB lower in addition to having much higher overclocking potential.<br>
<br>
<img src="http://marketing-uk.msi.com/images/afterburner.png" align="left" alt="afterburner" /><br>
<b>Overclocking Potential Unleashed with GPU/Memory/PLL Triple Overvoltage</b><br>
The MSI 6970 Lightning graphic cards come with the latest version of MSI's exclusive Afterburner V2.1.0 overclocking utility. The utility not only adjusts GPU and memory clock but also manage the GPU/Memory/PLL(VDDCI) voltages to maximize overclocking potential. Thanks to Triple Overvoltage, the overclocking potential of 6970 Lightning is much higher than the reference board and offers enthusiasts ultimate performance.<br>
<br>
<br>
<br>
<b>King of Extreme Overclocking</b><br>
For hardware enthusiasts, the MSI 6970 Lightning graphic cards come with exclusive extreme overclocking features. Apart from V-Check Points and V-Switch for monitoring and adjusting the GPU/Memory/PLL(VDDCI) voltages in real time, Dual Bios switches help to effectively prevent potential problems stemming from liquid nitrogen cooling. PWM Clock Tuner also helps to increase overclocking potential. All of these come together to make the 6970 Lightning the ultimate graphic cards for extreme overclocking<br>
<br>
<img src="http://marketing-uk.msi.com/images/mcii.png" align="right" alt="Military Class" /><b>Carefully Selected Materials</b><br>
The MSI 6970 Lightning graphic cards use top-quality Military Class II components including All Solid Cap for overclocking and full-speed operation, SFC for 10% higher efficiency, and 30% increase in maximum current, as well as Hi-c Cap with Tantalum core which boasts 8 times the lifetime of conventional solid capacitors. These high-quality components not only increase the graphic cards' overall service life but also enhance GPU stability.
<br>
<br>
<img src="http://marketing-uk.msi.com/images/MUSTHAVE.png" alt="Kit Guru Gold" /><img src="http://www.vortez.co.uk/contentteller.php?ct=content&action=file&id=21" width="200" alt="vORTEZ Gold" />
<br>
<br>
<Font size="5"><b>Specifications</b></font><br>
<br>
<b>Stream Processors</b> - 1536 Units<br>
<b>Core Clock</b> - 880 MHz<br>
<b>Memory Clock</b> - 5500 MHz<br>
<b>Memory Size</b> - 2048MB GDDR5<br>
<b>Memory Bus</b> - 256 bits<br>
<b>Output</b> - Mini DisplayPort*2 / HDMI / DVI*2<br>
<b>TDP</b> - 269 W<br>
<b>Card Dimension</b> - 310x127x40mm<br>
<b>Form Factor</b> - ATX<br>
<b>DirectX 11</b> - Y<br>
<b>OpenGL 4.0</b> - Y<br>
<b>CrossFireX</b> - Y<br>
<b>Eyefinity</b> - Y<br>
<b>AVIVO HD</b> - Y<br>
<b>PowerPlay</b> - Y<br>
<b>HDCP</b> - Y<br>
<br>
- World’s first 18 phase PWM on HD 6970.<br>
- Independent Memory Power support. <br>
- Copper MOS with 2x high current capacity. <br>
- Proadlizer*4 to optimized power supply. <br>
- Twin Frozr III Thermal Design with 26C cooler & 11dB quieter. <br>
- Propeller Blade technology for 20% more airflow. <br>
- Dual 9cm fans with dual 8mm SuperPipes for best heat dissipation. <br>
- Form-in-one heatsink covers memory and modules to dissipate heat efficiency.<br>
- Support voltage adjustment of GPU/Memory/VDDCI<br>
- Military Class II Components for longer product lifespan. <br>
- LPL (Lightning Power Layer) for the stable power supply.<br>
- Usage of the Micro/DIP switches on rear of card voids warranty - For extreme/expert overclockers ONLY!<br>
<br>
<b>- Now with Three Year Warranty</b><br>
<img src="http://emm.msi.com/admin/temp/newsletters/1226/3yearfinal.jpg" width="250" alt="3 year warranty" /><br>
- Supplied with Battlefield 3 and Deus Ex PC Games
Only £299.99 inc VAT.
ORDER NOW
Asus GeForce GTX 560Ti DirectCU II TOP 1024MB GDDR5 PCI-Express Graphics Card **Supplied with BattleField 3 & Batman: Arkham City PC game** @ £194.39 inc VAT
ASUS is proud to introduce the new ASUS ENGTX560 Ti DCII TOP to all our users. Using the unique ASUS DirectCU II Cooler the airflow is doubled and the noise level is greatly reduced by using flattened copper heat pipes which directly contact the GPU core to speed up heat dissipation for a 20%* cooler performance compared to reference. Keeping the card temperatures low also results in quieter operations thanks to reduced fan speeds!
The card also boasts Super Alloy Power which can create a 15% performance increase, 2.5 longer product life span and a 35?C cooler operation. In addition to this, the engine clock runs at a Pre Overclocked 900MHz, allowing users to enjoy high speed and an unprecedented gaming experience. Super Alloy Power is a special blend of elements formed using an ASUS exclusive formula, under extreme pressure and temperatures. The metals are highly-magnetic, heat-resistant and anti-corrosive used to reduce power loss, enhance durability and achieve cooler operation.
Super Hybrid Engine is an intelligent power consumption optimizer that switches between high- and low-intensity power profiles in real-time. This in turn can provide up to 15% improved performance. Furthermore the GTX560 offers a SAP CAP; this is back-to-back with the GPU to provide most efficient power supply for increased stable overclocking of up to 28%.
With exclusive Voltage Tweak technology also being a key feature of this product, the ENGTX560 Ti DCII TOP/2DI/1GD5 covers users for every possible over-clocking and over-volting scenario. With the complete package offered by this card users can easily boost their performance by up to 50%!
Features:-
- Core Clock: 900MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4200MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 384
- Shader Clock: 1800MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Warranty: 3 years
- Supplied FREE with Batman: Arkham City FULL PC game (subject to availability. Game is launched on 21/10/2011 downloads previous to this date will be declined) (Only supplied with orders purchased after 07/09/2011)
- Supplied with BattleField 3 Full PC Game download voucher!
Only £194.39 inc VAT.
ORDER NOW
Some great offers their as the games are recent and add great value to the cards, so don't miss out on this unbeatable value OcUK is offering. :)
Not too long before we see some ;) posts methinks...
Yup, increasing frequency of deals of certain brands of cards says to me, hold on for the new ones, not spend as much money on these as possible.
Gibbo, not to complain, but you guys wouldn't start doing deals without all the specifications bits as well. Its not so bad when its only 4-5 deals but those 30-40 items TWO deals are frankly horrible to read, forever scrolling.
The name of each item and a pic is more than enough, all the specifics are listed in the links anyway and the vast majority of this forum knows the vast majority of the specs anyway.
The posts just get painfully long(yes the irony, I know :p ) to scroll/read through.
Without specs and more as a list would be far more readable ;)
Mid December at the earliest and likely a paper launch at that or limited stock, not until Jan/Feb for good volumes of new lines. :)
Also the first new cards will be flagship cards too.
NOoooooooo.............................too expensive, want mid range first goddammit. Rant over. Dont see any incentive to buy these cards, gonna be tough to sell cards for the next month or so. Competitor doing a quality brand 560Ti with no games at a good price, way to go maybe but with the new cards coming I'm waiting.;)
Really?
Last two weeks we've seen record sales on VGA, certainly zero issues with selling product at the moment. :)
Special offers are always ongoing all the time whether or not a product just being released, is mid-way through its life cycle or approaching the end of its life cycle, the deals never stop.
Good to know from your point of view then Gibbo really dont want you guys to be struggling. I dont know if I'm wrong but it just seemed that a couple of months ago the 2Gb 6950 were commonly on TWO and regularly under £200 but not now £230-£240 with games maybe but I'd rather see some bare cards at reduced prices. Good to know Ocuk are doing well though and still my favourite etailer.;)
The 6950 is in shortage, hence higher prices typically and 6970 is very tight and 6990 is finished. This is why prices have gone up, basically supply and demand.
hmm I see adding the gams to the msi lightning has increased the price by £10, thought it was ment to be £290 pre-order but now £300.
or was it ment to come with the games anyway as the pic in http://forums.overclockers.co.uk/showthread.php?t=18336066 shows both games.
also with the icq 6950 don't think the people who bought it over the last couple of day(especially last night) would be too happy, not getting bf3 especially those who want the game.
It was £289 with no games, though the image was displaying Deus Ex by mistake and was very cheap. Its now £299 with two games which between the two of them are worth circa £40-£50.
Great news Gibbo I'll be in the market for a high end card to power the Hazro :) Going for a first time launch day purchase, don't forget to give the forum faithful a heads up ;)
PS: also agree with DM re. the less detail in the forum posting of TWO.
Really?
hehe, that doesn't mean there is incentive, just most people don't seem to get that £200 now on a card which will have a replacement in a month is just a bad idea. Meh, if sales dropped massively AMD/Nvidia in these situations might delay products to help give stock time to clear first so people buying at the wrong time help those of us looking for the new gen anyway ;)
Then again its not surprising there's record sales, BF3, Skyrim, MW3(ok not really performance needing but most people think new AAA title, time for new gpu), compared to any other time of year those 3 games were always going to have enthusiasts deciding to pick up new cards before the release.
Seems like you guys haven't seen the store's own TWO page...
http://www.overclockers.co.uk/thisweek.php
Those text links at the top underneath the TWO banner (Cable, Components, Consoles etc) jump down to the relevant section to reduce scrolling even more should you wish to skip some bits.
That page is advertised on the store front, right-hand column and 3rd box down. Could probably be linked to in the forum TWO postings to make even more people aware of it it seems :)
Yeah, that doesn't make the first post in this thread more readable, nor the TWO threads. Because thats what we have pointed out the THREADS for deals on the forum(because a huge number of people check the forum every day but rarely check the store) will first see a deal on here. But the posts are painfully long/big text/picture that its actually harder to get through the threads than is necessary.
I mentioned the TWO threads as they normally have far more items than this thread which makes them almost horrendous to get through, all the deal threads would be improved with less text what's on offer + picture is ample. If it has to be spec's, something like the clock speed line for overclocked graphics cards is all people really need, 2gb is in the name, brand, type of core, etc, thats all pretty common knowledge but I wouldn't know the clock speed of a MSI lightning edition off the top of my head, 2gb, amd, 1536 cores, 3d/eyefinity are all standard and just take up space.
