Battlefield 3 thread - Server details in opening post -
Status
Not open for further replies.
I've almost got Rocket Pods they any good?
They're great, as long as you get a decent run up you can always disable tanks on the first pass. If your attack run is long enough you can switch to the chain gun afterwards and finish it off completely. They're not great with infantry.
I've unlocked the guided missile and I'm not sure if it's just me being a muppet, but I think I might stick with the rocket pods. Out of the three or four times I've got a lock with the guided it has always missed and caused no damage, whereas the pods can be used on infantry and buildings as well, which the guided can't.
Man, wtf is with claymores detonation detection, I don't know how many times enemies have just walked in front of them and killed me. It really, really ****es me off
they are useless and wont trigger if the enemy is crawling/courched down while moving past them its a feature dice put in....
No no no, I'm talking like, they walk/run into the room with the MCOM, and I've got a claymore (or two!) covering a very wide arc of the entrance, and they just stroll on past it wasting me. Drives me bananas
Yes you can.
:cool:
trouble is, you lose so much peripheral vision with the night scope, it makes them pointless on shotguns.
You need to use a shotgun at close range, at which point you dont need a thermal scope to see the enemy coming.
exactly
its just a well edited video to make it look better than it is.
Ive used that shotgun with frag ammo its a lot worse than the standard ammo . You use a full clip to get 2 kills..... where as with standard you can kill 4 or 5.
It looks "cool" cos he has slowed it down and stuff.
It does give it quite a long range... but be careful at short ranges you can really wound or even kill yourself.
its by far the fun gun weapon for me, suits my playstyle perfectly.
can take out 5 people at close range and even works long range.
died a few times from my own ammo, but mostly its so much fun to use.
in short range it totally owns.
Bf3 is a noob game, its adapted for people who cant aim and shoot, so the game allows you to be able to gun people down without much effort.
then the netcode and client side hitreg makes low ping a pain to have on a server.
asus12 with exploding shells makes the game fun again.
:D
Unlocked the SCARH the other day, what a great gun (even with iron sights), Also didnt realise most guns can be set to 1 bullet mode. (I really am a CSS Player at heart).
I find when playing with people, even if your losing its lots of fun. but play by yourself and its just annoying as no one helps anyone atall
SCARH kills people by one less bullet than any other gun (sniper rifles excluded) so is a great gun and currently my preferred as an engineer.
I have just discovered the tactic of changing fire mode and it is great, it is easy if you remember to do it, especially as an engineer it can be vital for medium-long range, especially if you add a scope. I do it all the time now
I am also using the SCARH, best i have used so far.
Well duh :rolleyes: :D
The Scar is good, but not so good for medium/long range, the bullet seems to drop off quickly (not particularly realistic)
Status
