Lying around dungeons sometimes, can also buy them from some merchants (maybe blacksmiths?)
Cheers.
Do you get dorm room when you join winterhold?
Yeah mate.
Cheers.
Yeah mate.
You can improve it to Legendary straight after making Daedric/Dragonbone assuming you have the mats. It's not really the armour that's OP, it's more the upgrading it. The upgrade adds something silly like 60% more defense giving the chest piece 154 armour alone.cheers, ive heard that you can improve the armour you get so would be good to get the best armour and then improve it some more![]()
Does anyone know (or has found) where the warrior/fighters guild is?
Who can i speak to i need palce to store them dragon bones!
There isn't one. Closest you get is Companions.
Anyone know how to make the shouts you've unlocked with dragon souls more powerful for example the unrelenting shout when it gets fully unlocked when your with the grey beards?
Loving the mods/tweaks that are starting to come out already
Before.
With the mod
This is the mod I used and only lost 10 fps using it
http://www.skyrimnexus.com/downloads/file.php?id=131
Before.
With the mod
it cant be specs or installation problem. I got someone else to do it for me and they also have trouble but it works on there pc!A m I missing something here ?
I just killed a Dragon stood near it and was surrounded by a swirling gold whirlwind type affair yet I havent got its soul.
there should be a semi circle wall with writing in the middle.walk up to the wallthere should be a semi circle wall with writing in the middle.
