How do you tell play.com to giftwrap your stuff?
Argh!
If it isn't obvious, then they don't do it. A google serach seems to confirm this.
Argh!
this is unfair. Im stuck for ideas. Must stalk more.No pro blay moI found it cheaper elsewhere AND with gift wrapping
Still a bit more than the max but worth it tbh I reckon.
ive spent £20 and im still looking for stuff lol, should i stop?![]()
Look at the file size n00b.
And I would've worn it cainer, just for you.
*Checks Cleeecooo's MM access*
Sounds like a lot of you are spending over the suggested max £15 budget!
