- 25 May 2011
Looking to do this mod for my PS3, wondering what tool to buy to use + would it be difficult ?
Thanks so much
Thanks so much
Hole saw. Shouldn't be difficult at all, just make sure to line it up straight and to use the correct size hole saw, looks like this:![]()
And your gonna' need a drill of some sort.
You can then put the fan in place and mark out the mounting holes, then drill the required holes x4
Cheers guys
Just wondering would I be best having the fan pulling air out or pushing it in ? would be doing the same as in that pick, just unsure which is more better to use
Guys apart from a 140mm fan like you can see in the pictures, what else will I need to buy so I can screw it to the case? Will I need a grill as well?
Thanks so much!
Thanks so much
Just so you know (Im also termpted to do it myself as I have some spare fans laying around) it will probably make your PS3 less appealing to buyers if you intend to sell it second hand as you have modified it
I did this and other mods to my PS3 after fixed the YLOD after more than a year and it hasn't broken down yet (touch wood).
he's a vid I made![]()
Watching the vid it seems he is doing it via USB (white lead) can anyone explain how thats possible?
