Caporegime
- 9 Nov 2009
- Planet Earth
Would anyone be willing to do a few encodes with Handbrake?
If so you can download handbrake here.
Use the Normal Preset.
Set the Contrainer to MKV.
Set the Priority Level to High in the options.
When finnished each encode record the average FPS, select the Activity Window then Encode Log from the dropdown, the average FPS will be near the end.
Source files, the smallest one would be enough but if you can do all 3 that would be better.
Tron_Trailer_HD.zip - 268 MB
Splice_Trlr_1_1080P.wmv - 336 MB - Right Click Save As this one.
big_buck_bunny_1080p_surround.avi - 886 MB
My 1100 results for comparison.
Code:1100 24/7 OC 4.0GHz | 3.0 | 1666-9-9-9-24-34 Tron 43.162312 fps Splice 29.393965 fps Big 43.118412 fps
EDIT: Handbrake will max all your cores so keep an eye on temps, I don't want to be responsible for frying your lovely new chip
Cheers.
Tron Handbrake Trailer
i7 2600K @4.8GHz, Source HDD, Destination SSD, 16GB RAM
Tron work: average encoding speed for job is 53.848640 fps (included work log in case fps is took from wrong bit)
Code:+ title 1: + stream: E:\Tron_Trailer_HD.mov + duration: 00:02:28 + size: 1920x816, pixel aspect: 1/1, display aspect: 2.35, 24.000 fps + autocrop: 0/0/0/0 + chapters: + 1: cells 0->0, 0 blocks, duration 00:02:28 + audio tracks: + 1, English (AAC) (2.0 ch) (iso639-2: eng) + subtitle tracks: [13:06:00] 1 job(s) to process [13:06:00] starting job [13:06:00] work: sanitizing track 0 mixdown Dolby Pro Logic II to Stereo [13:06:00] sync: expecting 3596 video frames [13:06:00] job configuration: [13:06:00] * source [13:06:00] + E:\Tron_Trailer_HD.mov [13:06:00] + title 1, chapter(s) 1 to 1 [13:06:00] + container: mov,mp4,m4a,3gp,3g2,mj2 [13:06:00] + data rate: 15237 kbps [13:06:00] * destination [13:06:00] + C:\Users\FMTopFan\Desktop\tmp.mkv [13:06:00] + container: Matroska (.mkv) [13:06:00] * video track [13:06:00] + decoder: h264 [13:06:00] + bitrate 14914 kbps [13:06:00] + frame rate: same as source (around 24.000 fps) [13:06:00] + strict anamorphic [13:06:00] + storage dimensions: 1920 * 816 -> 1920 * 816, crop 0/0/0/0, mod 0 [13:06:00] + pixel aspect ratio: 1 / 1 [13:06:00] + display dimensions: 1920 * 816 [13:06:00] + encoder: x264 [13:06:00] + options: ref=2:bframes=2:subq=6:mixed-refs=0:weightb=0:8x8dct=0:trellis=0 [13:06:00] + quality: 20.00 (RF) [13:06:00] * audio track 0 [13:06:00] + decoder: English (AAC) (2.0 ch) (track 1, id 1) [13:06:00] + mixdown: Stereo [13:06:00] + encoder: faac [13:06:00] + bitrate: 160 kbps, samplerate: 44100 Hz [13:06:00] encx264: min-keyint: auto (24), keyint: 240 [13:06:00] encx264: encoding with stored aspect 1/1 [13:06:00] encx264: Encoding at constant RF 20.000000 x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2 [13:06:00] reader: first SCR 0 id 0 DTS 0 x264 [info]: profile Main, level 4.0 [13:07:05] reader: done. 1 scr changes [13:07:06] work: average encoding speed for job is 53.848640 fps [13:07:07] sync: got 3572 frames, 3596 expected [13:07:07] h264-decoder done: 3572 frames, 0 decoder errors, 0 drops [13:07:07] render: lost time: 0 (0 frames) [13:07:07] render: gained time: 0 (0 frames) (0 not accounted for) x264 [info]: frame I:104 Avg QP:16.63 size: 95877 PSNR Mean Y:51.19 U:55.75 V:56.69 Avg:52.20 Global:50.57 x264 [info]: frame P:2468 Avg QP:19.75 size: 27152 PSNR Mean Y:47.92 U:52.36 V:53.09 Avg:48.88 Global:47.14 x264 [info]: frame B:1000 Avg QP:21.47 size: 10223 PSNR Mean Y:50.94 U:55.32 V:56.07 Avg:51.81 Global:46.57 x264 [info]: consecutive B-frames: 49.3% 29.6% 21.0% x264 [info]: mb I I16..4: 59.4% 0.0% 40.6% x264 [info]: mb P I16..4: 25.9% 0.0% 5.1% P16..4: 39.8% 6.0% 3.0% 0.0% 0.0% skip:20.1% x264 [info]: mb B I16..4: 10.3% 0.0% 0.5% B16..8: 21.2% 3.5% 0.3% direct: 9.0% skip:55.3% L0:39.0% L1:49.7% BI:11.3% x264 [info]: coded y,uvDC,uvAC intra: 41.2% 50.0% 23.2% inter: 10.7% 23.7% 1.4% x264 [info]: i16 v,h,dc,p: 34% 24% 25% 16% x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 19% 25% 29% 5% 6% 5% 5% 4% 4% x264 [info]: i8c dc,h,v,p: 58% 21% 16% 6% x264 [info]: Weighted P-Frames: Y:16.1% UV:11.7% x264 [info]: ref P L0: 62.6% 9.1% 26.9% 1.3% x264 [info]: ref B L0: 67.8% 32.2% x264 [info]: ref B L1: 95.0% 5.0% x264 [info]: SSIM Mean Y:0.9863838 (18.659db) x264 [info]: PSNR Mean Y:48.863 U:53.289 V:54.026 Avg:49.797 Global:47.037 kb/s:4686.10 [13:07:07] aac-decoder done: 0 frames, 0 decoder errors, 0 drops [13:07:07] mux: track 0, 3572 frames, 87202379 bytes, 4684.63 kbps, fifo 8 [13:07:07] mux: track 1, 6413 frames, 2892381 bytes, 155.38 kbps, fifo 512 [13:07:07] libhb: work result = 0 Rip done! HandBrake has exited.
3960X 24/7 OC
5.0GHz | 3.3 | 2133-8-9-8-24
Tron 74.126457 fps
Splice 52.385559 fps
Big Buck 71.883835 fps
These look like the files I suggested for encodes in the BD thread as I have a thread on another website with the same files and settings.
I would appreciate it if I can add these scores to the thread(OcUK will be mentioned) as I have 67 results already and top score is for an i7 980X.
http://i559.photobucket.com/albums/ss33/CAT-THE-FIFTH/HandBrakeChart25-10-2011.png
