I don't think he will get much out of it, even if it's the ddr3 memory version.What's your budget and the rest of his spec?
At this point yes I would say the XBox is probably your best bang for buck. Not sure about PC gaming just being an enthusiast platform though. It does have some distinct advantages over it's console counterparts.
Yes but when it comes to cost i think the pc is going to loose even though i am a hardcore pc enthusiast
pcs can be put together quite cheaply with older tech but with shiny new games like BF3 they are going to srtruggle
Still dont know what the 4650 = in todays line up ? 5470 6470 etc as it says the minimum spec card is a Hd 3870 ?
A rough equivalent to the 4650 DDR 2 would be the 6450. If the game requires a 3870 as a minimum then look for a 6570 (GDDR 5) or preferably above, if at all possible.
What resolution is he running btw?
thats not that bad as a 6450 is only about £35 and about the price of a game
But no idea of the res ! but i would imagine low 19/20 inch monitor from about 2 years ago
also i think his psu should handle that and a lot cheaper than an xbox![]()
Don't order anything until you've checked out the Nvidia refurb deals, almost forgot about them...
http://www.overclockers.co.uk/productlist.php?groupid=701&catid=1914&subid=2077
The 6450 has dx11 but it's not a gaming card as such, well, at all really. I expect that it will run the game but very poorly, even at lower resolutions, unless you turn everything down to low or minimum. The 9800gt wipes the floor with the 6450.
http://www.tomshardware.co.uk/best-graphics-card-game-performance-radeon-hd-6670,review-32183-7.html
I myself would like to get rid of my 5850 in anticipation of the 7000 series but i don't think his system would handle a 5850
