The Elder Scrolls V: Skyrim announced
I checked through all your screenshots, very nice:D
I think the game looks amazing but I wish both myself and my horse made foot prints in snow/mud, would be good feature if the game devs add it later on in a patch.
I guess theres no game with perfect graphics though, even crysis 1 & 2 had some faults in certain areas. I guess to make every single texture and model in a game look perfect would be overkill, as long as everything looks pretty from a distance or when moving around and not really focusing on any one thing, I guess it works.
Thanks :) - I know what you mean about the footprints, would have been such a simple feature to add. Will probably be modded in by someone.
It is one of the few games where I constantly find myself stopping and staring at the scenery!
Fus Do Rah
How do I speak the 2nd word?
I've bound the shout to Mouse 3 and when I press it it only says the first word.
Please tell me how stupid I am ... :)
I noticed that! all that nice fluffy snow and no footprints.
How do you think the following would run the game? =)
Intel i7 930 2.8GHz Socket 1366 8MB L3 Cache
Gigabyte GA-X58A-UD5 Intel X58 Socket 1366 8 Channel Audio ATX Motherboard
Corsair 6GB (3x2GB) 1866MHz Dominator Memory
XFX HD 5870 1GB DDR5 Dual DVI HDMI Display Port Out PCI-E Graphics Card
Sony AD-7240S 24x DVD±RW DL & RAM SATA Optical Drive
2xWD 1TB 3.5" SATA-III 6Gb/s Caviar Black Hard Drive - 7200rpm 64MB Cache
Arctic Cooling Freezer 13 Cpu Cooler
CM Storm Scout + Coolermaster Silent Pro 700W Modular PSU
Well that spec is 10x better then mine and mine runs it fine on ultra settings with almost everything maxed out so you'd have no problem what so ever. :p
I have amd x3 3.2ghz, 4gb ram, 5770 1gb and I get 60fps indoors, 40-50 outdoors.
Is there a way to find dragons when you want one or is it just a case of luck and you'll just see one when you come across one accidently? Or are there places where they spawn?
It's just I learnt a new word and wanted to activate a new shout but need a dragon soul :D
Goto places you have already been to, generally.
Or special places with a certain ;) map marker.
There are areas on maps which highlight dragons, usually on top of mountains. Also at a certain point in the main quest line you are given a map of burial sites which have dragons at them.
What is the point of the bards college? Is it fun?
It's ok.
Quest spoilers:
Disappointingly, you can't learn to play instruments. :(
After getting in there's only like 3 quests, but I could only figure out how to do 2 of them. They're all just fetch quests anyway "so and so got his flute stolen, will you get it back for him" etc.
