Pastel it is then![]()
Pastel works on every thing so you'll be fine with that.
Thanks. Would I be ok to add some dye to the pastel coolant? I'm trying to keep it close to the Asus ROG / EVGA red colour scheme and the light red looks a bit... light and the dark red has a hint of brown in the pictures I've seen.
If it would be ok, would you suggest starting with the white or the light red?
Not too bothered about staining as the tubing gets changed far too regularly anyway and I can't see the insides of the blocks.
thanks, I don't think I can use aurora in my Rig then
does pastel have any particle settling effect or is it 100% suspended?
If left over a 2 month period it falls out at about 10 to 15% (leaving 90 to 85% suspended) How ever due to it 40nm size with will be re-suspended with in seconds of the pump turning back on.
thast pastel not aurora, aurora drops out in 15 min of turning off. Aurora is a different kettle of fish.
I cannot say what it will be like in a chiller, i have not tested it in mine.
