If 192.168.0.1 doesn't work, google the model of the router for the default ip address.
Just open a command prompt (start - run - cmd) and type ipconfig. The line that reads "Default Gateway" is your router IP.
[TW]Fox;20609107 said:Just buy a 3G dongle, problem solved. Then you've got your own personal laptop with its own personal internet connection that is entirely your business!
Can't see how this is being made such an issue.
No worries, tbh you don't even need a 3G dongle.. depending on what phone you have, you can tether it. I know the new iPhone iOS5 allows tethering now and pretty much all android phones do.. your biggest problem there though is monthly/daily allowance unless you're on an unlimited tariff for internets
Generally with the dongles, if your phone signal/network is good then your dongle will be to.. trial and error and I think they'll refund you if your coverage sucks
I'm guessing hes hosting some nasty site or hes downloading some nasty stuff and is trying to keep you all away from the internet.
Or hes not really very up on computers and doesn't want to look a muppet.
On the games having viruses and nasty stuff in them. Most companies had similar thoughts 20 years ago, and still do so if hes stuck in that timewarp I can understand why he thinks that way.
Dont get the win7 hatred though, again maybe he likes to be super techy or thinks he is and cannot lower himself (or you) to that nasty Windoze stuff.
Does he shop online etc?
Globul I think you need to find yourself a rich boyfriend pronto and move out
Does your mother let him control all her life in the same way he controls your internet?
Surely if she can afford to buy you a house and rent it back to you she can help you out now and get you a dongle to make you happy. Mother and Daughter bonding and all that
Why does he not like Windows 7???
Don't tell me it dates back to the time when Microsoft milked IBM in the 80's.
If that's the reason why then he is an idiot.
More than likely! My mum worked for IBM then and she still doesn't like MS
Well it's their own fault (IBM).
Are your parents really that bothered about what OS you use.
Can't really afford a tenner a month on internet at the moment otherwise I would have gotten my ownPlus, I am not sure about dongles, I have always heard negative things about them? I am in a poor internet area anyways
My mums not that bothered, she uses MS now and she's the one who told me to just go on the wifi on Win7 while he's out if I have the password and things
