[TW]Fox;20609271 said:It's 10 quid a month! I'm sure you can afford 3 less drinks a month at the pub if the internet issue is causing you such a big deal?
Infact if you use less data its probably even less than 10 quid a month. Do you have a half decent phone? You could probably just tether that using your existing service plan!
I don't go out drinking
I have a Nokia C3 on PAYG
Just how poor is your internet, I am assuming its broadband. Can you run a speed check?
Maybe hes blocked anything that he thinks will consume bandwidth and that you may use as its a really poor connection.
On a speedtest website it came out as Ping: 245ms DL Speed: 0.11mbps UL Speed: 0.06mbps
