Begbie, many thanks matey, really generous of you! I agree, being an existing customer sucks!
Anyone run anytime + using 200 mbps homplugs? Was thinking about using a couple of TP-Link TL-PA211's. The sky HD box is downstairs, the routers in the bedroom...
I use old homeplugs, the slower ones before the 200 mbps where available (forgot the exact speed). My router is downstairs and my HD box (anytime+ box) is upstairs and have no issues at all with old homeplugs, so i would'nt worry about 200 mbps ones.
My internet connetion is only 5meg, so my issue is the wait at times for downloads especially HD content, home plugs won't be an issue and work very well, your connection speed will be the key factor.
sky boxes can be networked?![]()
For Anytime + do you still need to be on Sky Broadband?
Yes, despite the fact that when Sky launched Anytime+ over a year ago they said it would be for Sky Broadband customers first and then they would release it to other ISP's. They're still using it as a way to try and get as many people onto their broadband as possible.
I've used Anytime+ at my brothers and if you have the movies pack it looks great, but there's no way I'm downgrading from BT Infinity to Sky BB for it.
@easyrider
Most of the newer sky boxes come with an Ethernet port for use with anytime +, all the HD boxes certainly do, think they even do a small normal one that does it to as well.
Does anybody do a VPN type service that provides access, or is the system locked down in some other way the Network prefix?
Do you need sky bb? or will it work if I connect the boxes to the net?
Is Anytime+ actually any good?
You need a Sky BB LLU connection for Anytime+.
It's very good for movies, there's a lot of HD movies on there now. For other content I don't think it looks too great from what I've seen. Virtually everything else is only available in SD, and there are hardly any complete boxsets of tv series.
Sky's FTTC (or even FTTH depending on where you live).
hi easyrider
I have Sky LLU and never get slowdowns at all, my 23997 kbps connection in router was downloading battlefield 3 update at 2.4MB/s to 2.3MB/s last night around 7 pm, I am living very very close to my telephone exchange.
Kenneth
? whats FTTC and FTTH?
