No problems so far, just the usual lag, but thats more than likely my own connection which isnt great tbh. If i experience any issues ill add them to your problem thread.So has anyone here not experienced a problem?
Lol. Not this again. If this is a cheat then so is every unlock in the game as they all give a unfair advantage against new players.
Lucky you, but Rage which came out quite a while ago still hasn't been fixed for ATI. Like I said, only dice could tell you how many of their userbase are having issues in comparison to say Crysis 2 (also plagued with issues on launch and 1st patch), but considering their sales of the game, I would say that the amount of people whining is still normal for BF game (about anything and everthing).
If they would just nerf the irnv for daylight use, it would be a bit better. I thought nv equipment didnt work in daylight anyway?
Hi all
Using Avira software and its picking up malaware in the new patch, what is the best option to take get the computer to ignore it or send it to quarantine ? I have a feeling if it goes to quarantine it wont install the game. thanks
Especially if you're playing against a high ranking squad.
The squads with OcUK lads in quite regularly have Squad Ammo, Squad Spring, Squad Flak, and maybe even squad explosives as well. So members of that squad have all the usefull specializations all stacked up against oppositon that maybe don't even have any yet.
Combine that with their F2000 or G36C they might be running around with, your at a severe disadvantage.
I think part of the problem is that DICE aren't sure quite HOW to balance it. They don't want to remove it from the game as it does have its uses - it is supposed to make it easier to find players. But the question is how to balance it such that players don't moan too much.
Personally i think if they removed the IRNV altogether, the next moan would be the USAS, and then the next moan would be frag ammo, and then the next moan would be that machine guns are too accurate, and then the next that engineer guns are too good, and that everybody should have C4 etc.. etc..
It would just shift the moaning and whinging onto something else.
avira = false positives for lots of games
Hi all
Very cool indeed, my experience of nv equipment is limited to 1st and 2nd generation russian stuff, (used for fox shooting). Not great tbh. Far better off with a lamp.The IRNV is based upon a new scope, called ENV - enhanced night vision.
It combines thermal imaging with infrared image intensifying night vision into the same scope.
If you watch the manufacturers adverts
http://vimeo.com/4532787
You can clearly see the military training with them outdoors in the day light at 01:00
and again in this
http://vimeo.com/16744235
Pretty cool stuff.
and again in this
Pretty cool stuff.
