Battlefield 3 thread - Server details in opening post -
Status
Not open for further replies.
The Assault class weapons are all a bit too similar if anything, the exception being the AN-94... which hit every branch of the underperforming tree on the way down.
And the G3....its pants at close range, doesn't fire enough bullets to beat somebody spraying with any other weapon, buts its excellent at longer ranges, much better than the M16 or F2000. In my opinion, of course.
Not a fan of the AK scopes, looks far too much like a sniper scope for my liking. Picked one fof the ground in a game a few mins back and thought it was a sniper rifle for a while. :o
Could be right Rojin, then it could be testing inaccuracies as well. Despite the variations it's still the same hits per kill ratio with the big 3 MGs, and thats where rate of fire becomes more important than a small variation in damage.
I've been enjoying obtaining the addons for the rank unlocked guns. Got all the upgrades for the UMP, PDW-R and working on the P90 now. All engineer and assault unlocks have been obtained (apart from co-op) and half way through support at the minute.
Brrr lock up, even after a much longer playing time last night without issue. Good thing I have a headset to fall back on.
I get mad when I kill someone and their cool gun doesn't have a scope attached, makes finding them all the merrier! Although not good for mission objective :p
Yeah I was just using the M60\M240B as an example as I knew they had a difference, albeit a very small one! (I really struggle with the M60 for some reason so had looked into its tech stats).
yea they messed up my scar, pretty much anyone here is free to add.me, 'ballist1x'.
Yeah up to 10m away it outgunned the F2000 but not anymore. Bad enough that over 10m the F2000 killed you 0.018 secs quicker but mad to nerf it as they have so its slower overall. The F2000 needs nerfing now but then where do you end?
I disagree with the nerfing as each advantage had to be earned but usually there is always a defence against it which can be earned as well
Planes and helis now have a major advantage and a good pilot with loads up upgrades could always rule the skies even against a fully loaded AA.
Playing tanks on levels with good pilots now is no fun as it's a tank massacre unless your side has good pilots as well to keep the planes and helis away from you.
You may as well lob potatoes at the heli's.
It is a bit of a strange one where you have more chance of hitting a plane or a heli with an RPG or a tank shell than you have with a stinger missile.
Most helis i have disabled have just managed to land it safely, repair and then back up like nothing has happened.
They mentioned that they changed the physics of AA guns and i agree it has been changed. It is now impossible to hit a single jet.
Seen my accuracy go down from nearly 14% to 12.3% just trying to hit a jet.
Didnt register a single hit, at all.
The match server is exactly what it says :D
Not sure if the guys had arranged a match with you or not, but that server is ofc for when we're in ladder or friendly matches so isn't public.
Indeed I thought it was a bit strange that it said "match server" but sin-password. Assumed it had finished and password removed. Apparently not. So sorry for any inteference but...a bit sloppy!
Status
