PSU help
thanks for the extreme outervision link for calculating wattage requirement. As it happens main pc died (suspect its the psu) so about to RIP it out and whack the one from here in it, hopefully it is powerful enough and has all the relevant leads... it is 6 years old :/
Wish me luck
Those two are about the same really, the advantage of the water cooler is you can have tall RAM and it leaves the inside of the PC a lot more "open" when you dont have a chunk of metal in there.
lots of people seem to be suggesting the Gelid Tranquillo CPU Cooler is there any advance of using it over a water cooler or the other way round?
