the stronger the signal is the closer you are to it , you dont need to be connected to the router either.sorry for being silly but wondiered if this was possible and if so why it doesn't happen all the time.
set up a wireless network, call it something like "free wifi" then pu a tracker thing on it so it records all the data it receives like login details, then use them to whatever site the person went on, profit?
passwordsarenormallyencrypted = fail
i know for a fact everyone here is speaking BS
i know for a fact everyone here is speaking BS about most of these names as there are programs out that let you trace where a router is.
like that hot and cold game children playthe stronger the signal is the closer you are to it , you dont need to be connected to the router either.
if you were hardware savvy you would have your router as invisible so it doesnt show up on a list of networks and the only way to connect to it is if you know the ssid
Makes no difference. Mine is set to invisible, but can easily be tracked using free programs. InSSIDer is one of them.
