- 12 Sep 2005
- Norwich, England
You can still use anytime just not anytime +.
There will likely be a multiswitch, connected to Quad LNBs on the communal dish.
borrow a neighbours?
Whats the difference?
The trick to timed recording (ie- when you're out) with a single feed sky+ box is to look on the planner and go through the motions of setting a program to record, that starts prior to the one that you actually want recording - but make sure it is still on when the wanted one starts. You then set the program you want to record as well.
You will find that the first recording fails but the one you wanted d!
