No im not happy, the system froze at stock volts 3.8 Ghz in Prime 95, and it wont do 2000 Mhz ram :mad:
Trying 1.225v 3.8 Ghz, 190 BCLK, 1900 Mhz Cas 7 ram.
Well, that joke back fired :/
What's the spec of your memory?
Have you tried just testing 3.8Ghz at stock memory values or what the MB doesn't class as an OC?
Super Pi 32m passed at stock volts, 3.8 Ghz, 1900 Mhz Cas 7 Ram.
Prime 95 running for 5 mins so far.
WOOOOT
Forgot to enable 100% LLC, testing stock volts 3.8 Ghz again
This chip is giving you bipolar tendencies - euphoria then lows - they should have supplied lithium along with the HS. :)
First successful OC with no crash - 4 Ghz @ 1.3v! (Might manage lower, havnt tested that yet).
My I7 920 needed 1.34v for 4 Ghz.
Update - 1.275v @ 4 Ghz working.
Now 1.25v @ 4 Ghz is working (ram speed down to 1600 Mhz Cas 6).
The ram was causing the crashes before, the CPU is great :)
Get it straight to 4.4GHz or something and then work from there. 4GHz is a piece of cake on Gulftown. Remember a 4GHz 920 is a 50% OC whereas 4GHz is nothing to the Gulftowns.
4GHz is a piece of cake on Gulftown..... 4GHz is nothing to the Gulftowns.
Indeed, my initial attempts were foiled by trying to OC my ram at the same time.
Stock voltage, 4 Ghz, Prime 95 + SuperPi passed at the same time:
Such an improvement already over needing 1.34v for 4 Ghz on my I7 920 :)
I'm going to be keeping my R3E + I7 980 till they go obsolete.
