I'll happily pay more for Nvidia drunkenmaster.
There is also a good reason to buy AMD if most of the next gen consoles are going to use AMD graphics hardware as well.
It's like the old saying, you get what you pay for isn't it. I'd rather pay more for a higher quality component, even if it performs the same its less hassle in the long run![]()
"You get what you pay for" - you're seriously saying that a GTX 580 is worth nearly 2x 6950s?
No, but certainly you'll get a better overall experience. It's well documented the crossfire setups suffer from microstutter and game compatibility issues. The GTX580 being a single, faster GPU is better if you can get away with it.
I'd ALWAYS go for a single GPU setup if it's powerful enough over a SLI setup for that reason regardless of if it was AMD or Nvidia who made it.
And?
Microstutter just doesn't happen in well optimised games anymore...
The only game I have witnessed microstutter on is crapsis2 and that game was so god aweful I didn't want to play it anyway!
My AMD 6950's have been rock solid, if the 7XXX cards are as solid Nvidia will be crapping their pants
If HD7870 >= HD6970 and HD7850 >=HD6950 then i'll be happy.
To be fair, if you look at the specs of each GPU that's where performance is most likely going to lie, maybe a little higher due to the lower process enabling better clock speeds.
I think its more along the lines of 7970=>6970 and 7950=>6950 according to the roadmap.
No thats not what is expected performance wise. Its believed the 7870 will perform similar to or better than a 6970 and the same goes for the 7850 over the 6950.![]()
it has absolutely **** all to do with how well a game is optimised, it's down to fps, and how well they're fired out... if fps gets low enough, you get it.
well, most games will come with optimizations by default for AMD graphics cards. That is the way I see it seeing as these days most games are developed for consoles first and then adapted to PCs.
Sorry but I don't buy that at all.
Aren't current gen consoles ATI chips? Yet I would say when the consoles were released, nVidia were leaps ahead of ATI. Remember the 8800GTX domination?
