** Today Only 26/11/2011 - 28/11/2011 ** - Intel i7 980 and MSI GTX 560Ti 2048MB
20 Jul 2009
Midlands
Today only we have 10 bits of the Intel Core i7 980 3.33GHz (Gulftown) (Socket LGA1366) - Retail at just £419.99 inc VAT saving £20.00!
We also have 60 units of the MSI GeForce GTX 560Ti OC Twin FrozR II 2048MB GDDR5 PCI-Express Graphics Card for just £199.99inc saving an incredible £55.00!!!!
Intel Core i7 980 3.33GHz (Gulftown) (Socket LGA1366) - Retail @ £419.99 inc VAT
Dominate your gaming competition with the six core Intel Core i7. Thanks to the latest ultra-threaded, killer combination of smart features, including Intel Turbo Boost Technology and Intel Hyper-Threading Technology, the Intel Core i7 980 is Intel’s most capable and downright devastating PC processor ever.
- Core Size: 32nm
- Socket: LGA1366
- Six Core
- Frequency: 3.33GHz
- Multiplier: 25x
- L2 Cache: 6x 256KB
- L3 Cache: 12MB
- QPI: 6.4 GT/s
- TDP: 130W
- Includes Heatsink & Thermal Paste
Was £439.99 Inc. VAT
Only £419.99 inc VAT.
ORDER NOW
MSI GeForce GTX 560Ti OC Twin FrozR II 2048MB GDDR5 PCI-Express Graphics Card @ £199.99 inc VAT
Twin Frozr II Thermal Design 20 Degrees Celsuis Cooler!!
- Dual 8CM PWM Fans for 50% more air alow can cool down GPU/Memory/Power Module at once.
- Four heat pipes with SuperPipe Technology
- Nickel-plated Copper Base : Large size of Copper Base can dissipate the heat of GPU faster.
7+1 Phase PWM Design
- Higher current to GPU Powerv
- Higher overclocking capability
- Better stability in peak load
Military Class Components
- Hi-C Cap provides more precise GPU voltage.
- SFC (Super Ferrite Choke) : 30% Higher Current Capacity, 10% Power Efficiency Improvement.
- All Solid CAP for longer lifespan.
- Dual 8cm PWM Fans for 50% more airflow.
- Superpipe technology and nickel-plated copper base for better dissipation
- 20c cooler than reference design
- Military Class II Components
- Core Clock: 880MHz
- Memory: 2048MB GDDR5
- Memory Clock: 4008MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 384
- Shader Clock: 1760MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Now with Three Year Warranty
Was £254.99 Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
Fairly close, the reason this card is so good is that the VRAM allows for even greater performance in demanding games.
The cooler is really quiet and looks great too! most of the 570s have louder coolers than this and run a lot hotter too
The FrozrIII as rjk says above is fantastic, mines been runnign aince I gto italbeit a 6950 version, deadly silent even when I've been gaming.
Very high build wuality as well :)
And dammit rjk thats not a 2500k chip :( :p
ALERT: :D
How does this compare to Sapphire hd 6970????
Because i think this gpu looks awesome and is much cooler than my 85-90C sapphire card? would also look amazing in my white/black/grey colour scheme.
Blame Andrew Moore :o
or if you plan on playing BF3
(check out the 1GB vs 2GB comparison floating around the news section somewhere)
that's right, expect more games to be heading this way in future.
I for one welcome it, pushing hardware means i am getting my moneys worth rather than just playing console ports :p
Pushing hardware means i am getting my moneys worth rather than just playing console ports :p
Im sure many people already know this around here but i have a fact of the day for you all.
Over 90% of PC games are not paid for, hence they design for console and port to PC because all the money is in PS3 games that cant be as easily stolen.
I think OCUK and other large PC companies should really focus on trying to stop this. We would get much better games if people actually paid for the hard work that is put into making them.
I'm still only seeing an average 30'ish frames per second...if thats enough for people then go for it, but for me, fast online FPS games need frame rates in the high 40's or low 50's as an absolute minimum, which a 2Gb 560 SLI setup would easily deliver @1080p or above.
Well if you enjoy 15fps minimums with an average barely squeaking past 30fps then go right ahead.
Meanwhile back in the real world everyone else would just drop a couple of settings that make no noticeable difference while gaming and get identical performance from the 1GB card.
