Can you not delete/remove the Google search bar? Or is it always there?
Sucks if you cant remove it!
Shimmy can I ask you firstly what Widgets you have running for weather? It looks like mine using advanced clock widget? But you have a cloud? Is that the paid version that gives the extra info? And also those toggles are cool, where did you get them?
As it stands you can't, hopefully it's optional in the future. There are already some ROMs which allow you to remove it.
Using Fancy Widgets (free version) with the Fancy Weather Classic skin.
The toggles are switchpro widget.
Ok finally got my nexus, p4u had the cheek to sell me a used unit, i naturally told them where to go.
The sound is superb, whatever dac it has it's a quality unit.
can we ota while rooted?
anyone know a good site for 1440x1280 walllpapers for this phone?
