Battlefield 3 thread - Server details in opening post -
Status
Not open for further replies.
Weapons are pieces of metal, you can fit anything you like to gun if you have the skill and the tools.
There's a massive gun smith industry in the US based around customising guns, fitting stuff to them that was never intended, even converting civilian guns back to their military spec in the states where automatics are allowed (like Nevada)
You could fit a silencer to a GPMG, (M240b to the yanks) but its so damned loud it wouldn't make that much of a difference
I bet heat would be a problem too. The 7.62mm guns can easily overheat if used continuously
Amen to that, some machine gun barrels become so hot they glow and will burn straight through to the bone if touched. Heard some horror stories from my army mates.
When i type 'smogsy' into the filter bar, i don't get any results. How do i get onto smogsys servers?
it should come up fine that how every one else finds it fine.
it might been me updating it at the time /rebooting it ready for increased players.
@stoned - NO RUSH just pure conquest with BIG MAPS & increased tickets
For M+KB do you have:
W - Throttle up
A - roll left
S - Throttle down
D - Roll right
Mouse for the little adjustments to help aim?
I can not fly with M+KB but want to get into it, As i get smashed using a 360 controler
Try these controls it has helped me:
W- Pitch up
A- Roll Left
S- Pitch Down
D- Roll Right
Mouse Left - Yaw Left
Mouse Right - Yaw Right
Mouse Up - Pitch up
Mouse Down -Pitch Down
Put what ever you want for :Throttle down/up
Mouse + keyboard is the way forward. I stubbornly tried to stick it out with my joystick but you just can't aim with that thing.
Agree, but you simply can not consistenly out-turn someone with a pad/keyboard.
With a high sensitivity you certainly can.
ever thought that maybe its your pc?
I did ask if there were things to check a few pages back but to no avail.
The game worked fine pre-patch, a few crashes here and there but nothing major. Since the patch I can't play for longer than 2mins.
I tried doing the manual PB update and checking for new gfx drivers.
Ever thought that I'm also getting crashes sometimes within 1 round sometimes within hours and it's been ever since this latest patch..
There are HUNDREDS of page replies about this exact same issue on the battlelog forums, one or two people yep it's there system but hundreds of replies no
This what leads me to think it's not me (the pc), pre-patch it was almost fine, post patch = unplayable. I've seen people with i7's and ridiculously expensive machines having the same troubles as me :(
see i very rarely crash, maybe after 3+ hours of gaming straight. post and pre patch :cool:
I never, ever crash. I just have issues actually getting into the game. It can take 3/4 attempts to join a server sometimes then other times it's absolutely fine. Very random.
Do you have realtek sound cards?, just trying to pin point the issue..
Even ocuk staff made a thread on the issues with BF3 :D
Only time I seem to crash is if I minimise the game at some point. If I do that, then there seems to be a random chance that I'll get a bf3.exe has stopped responding at some point. If I don't minimise, then it's totally stable for me.
Although I can't remember getting any bf3.exe stopped responding since the patch. So not sure if it fixed that for me or just been lucky.
Haven't had any hard locks, using an old pci sb x-fi card.
The only crash im getting is bf3 has stopped responding. Usually happens on the first round of the day, get it at stock or oc'd. Im using an asus xonar DX for audio.
I crash 3 times on joining a server every time.
1st time the .exe stops working.
2nd time I get a server error.
3 time ea server error.
4 time in game ok.
crashed mind game 1 or 2 time.
Status
