BeQuiet 600W Gold Rated PSU - Less than £50
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys
You can now buy a 600W 80PLUS Gold (up to 92% efficiency) PSU for as little as £49.99 inc! To put things into perspective.. a Corsair 600w PSU is £59.99 inc VAT which is only 80PLUS.. not even 80PLUS Bronze.
It doesn't scimp out either on connectivity.. 4x PCI Express (2x 6+2-pin and 2x 6-pin) & 12V P8 connection (P4+4), and to top it off you get a world famous, epic 120mm silent be quiet! fan
It's a no brainer!
BeQuiet Efficient Power 600W '80 Plus Gold' Power Supply @ £49.99 inc VAT
The highly efficient '80 Plus Gold' power supply provide a typical 92% efficient unit to reliably and safely power your PC. Whether it is an office machine, a multimedia beast or a monster gaming rig this unit is ideal for all. With four +12V rails this can support all of the latest hardware including 2 GPU's as it has four PCI-Express power connectors and can power up to 6 SATA devices and and 4 molex powered devices.
- 120mm high-quality fan with a reliable silent bearing.
- Active clamp- + SR technology for very efficient and stable operation. Compatible with ATX 12V V2.31 and EPS 12V V2.92.
- Effective continuous output of 600W.
- Four independent 12V rails.
- Supports the latest generations of processors from Intel and AMD.
- Very efficient and power-saving operation
- 80PLUS Gold certification for the highest efficiency of up to 92%.
- ErP Lot 6 ready.
- Power consumption in stand-by mode <0.5W.
- Fulfils the requirements of the Energy Star 5.0 environmental and energy-saving guidelines.
- Suitable for multi-GPU operation: 4x PCI Express (2x 6+2-pin and 2x 6-pin).
- High compatibility with future as well as older components:
- 12V P8 connection (P4+4).
- Top safety and reliability
- Top protection for your components (OCP, OVP, UVP, OPP, OTP and SCP). Certified in accordance with international safety standards.
- Engineering, design and quality control in Germany
- 2-year manufacturer’s warranty
Was £64.99 Inc. VAT
Only £49.99 inc VAT.
ORDER NOW
Is it any good quality wise? Trusted so it won't die within a few days?
Also sorry but will it be ok if I buy it and it sits around in it's box for a month or two? Until I build in January.
Will this be suitable for a 4.6ghz+ 2500k, one of AMDs soon to be released cards (or a 580 for comparison) and 16gb ram? I might have to take the offer up if it is :p
Cracking price me and my mate both running be Quiets, and they are indeed very quiet :)
Only niggle is some of them from what I've seen have propreitary connectors rather than the standard Euro plug thingy, might be a pain if you wanted to use a longer than standard cable.
