any advice for a newbie?
Thanx for the quick reply
device manager says.....
disc drive is ST350083 OAS disc device
dvd drive is AD-5170A ATA device
IDE ATA/ATPI controllers
ATA channel 0
ATA channel 1
NVIDIA nforce serial ATA controller
standard dual channel PCI IDE controller
would there be any around this?
cheers nige
open the case, does it have big 'fat' ribbons, or 'thin' cables(usually red) connected to the drives from the motherboard?
I'd suggest getting the parts seperatly rather than the bundle and save yourself £40-£50
ATA channel 0
ATA channel 1
cheers nige
lets see if I cant get you sorted, does your PC use these?
Or these,
Double check the hard drive cables, just to be sure. A 4 year old rig should have sata cables for the hard drives by then, mine did anyway.
Well thats just saved you £85.
Take the HDD away from the above, check to see how much room there is in your case from the CPU surface to the side panel to check the Cooler fits inside.
seagate barracuda 500 gb
That will do nicely.
Your basketProduct Name Qty Price Line Total
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM £155.99
(£129.99) £155.99
(£129.99)
Gigabyte Z68AP-D3 Intel Z68 (Socket 1155) DDR3 Motherboard £84.98
(£70.82) £84.98
(£70.82)
Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-02050) £79.99
(£66.66) £79.99
(£66.66)
Kingston HyperX Blu 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9AD3B1K2/4G) £19.99
(£16.66) £19.99
(£16.66)
Arctic Cooling Freezer 13 High Performance CPU Cooler (Socket LGA775/1155/1156/1366/939/AM2/AM2+) £17.99
(£14.99) £17.99
(£14.99)
OcUK 22x DVD±RW SATA ReWriter (Black) - OEM £17.99
(£14.99) £17.99
(£14.99)
Sub Total : £314.11
Shipping cost assumes delivery to UK Mainland with:
FREE SHIPPING (DX Secure Next Day)
(This can be changed during checkout) Shipping : FREE
VAT is being charged at 20.00% VAT : £62.82
Total : £376.93
