***** The Official Fifa 12 Thread *****
if you have enough time to switch before you concede a corner, good luck to you.
i leave it on normal and play with a custom formation. works fine.
Which sadly has to be customised every game in game doesn't it? :(
Miss my custom 4132 from last year :(
------------------- IF Buffon --------------------------
Maicon - TOBRanocchia - Chiellini - TOTY Balzaretti
-------------------- IF Camiasso --------------------
- Hernanes ------ TOTY Lavezzi ------ Ronaldinho -
------------ TOTY Aguero ----- Ronaldo -------------
Used to love 'em!!
Anyone use the d-pad?
I usually just leave it on one setting but was reading a guide explaining how to use it better.
Basically.
When off the ball - High Pressure
When on the ball - Possesion
when an attacking midielder is about to pass to an attacking striker - offside trap
when conceding a corner - counter attack
and to never cpu contain in the middle areas of the pitch, only cpu contain in wide areas. One of my biggest problems.
Do all you lot use those tactics? Only thing I use is defensive or attacking! Am I missing an obvious advantage?
IN PACKS FROM 5pm GMT
Link - http://www.ea.com/uk/football/fifa-ultimate-team/show-off#eAjMZU7Bbb5RB
Starting XI:
GK - Tim Krul - Newcastle - 74 > 80
RB - Varela - Getafe CF - 72 > 79
CB - Felipe Santana - B.Dortmund - 75 > 80
CB - Naldo(SIF) - W.Bremen - 80 > 84
CM - Amalfitano - Marseille - 79 > 83
CDM - Javi Garcia - SL Benfica - 80 > 83
RM - Pepe - Juventus - 78 > 82
LW - Juan Mata - Chelsea - 85 > 86
CDM - Lucas Leiva - Liverpool - 78 > 82
ST - Derdiyok - Bayer Levekusen - 79 > 83
ST - Adebayor - Spurs - 82 > 85
Subs Bench:
GK - Kim Seung-Gyu 62 >64
CB - David Edgar - Burnley - 66 > 73
CAM - Costa - Valencia - 78 > 81
LM - Lugo - Monarcas - 68> 73
RM - Karadeniz - Rubin Kazan - 77 > 80
ST - Gary Hooper - Celtic - 76 > 83
ST - Giroud (SIF) - Montpellier - 76 > 83
Mata, Lucas and Adebayor. Nice.
Does anyone know if you can have a standard player in one squad and an IF (of the same player) in a different squad, at the same time?
Have just aquired myself a certain Mr. Nando Torres for my team, cost me 48,500 in correct formation and position which I didn't think was too bad. First XI nearly complete now, just need to bag myself Cech for Reina and that's the first team sorted....for now. After that I think i'll get Gazza Bale and put him on RW for a dark green boot instead of Gervinho and see if that works out any better. Gervinho ain't bad at all but i've heard good things about Bale. Putting him on the right means he can cut in on his left :)
Here's my team:
http://www.ea.com/uk/football/fifa-ultimate-team/show-off#bR0UbUyibb54u
Ignore the subs as I kinda haven't got round to buying any :p
Would love an IF Mata but will cost too much. Will try and get myself an IF Adebayor though, stats look great.
Also SIF Naldo has an 82 for shooting? WTF?
He scored a belter against Stuttgart from a freekick
Ah fair enough. Wonder how many people with him will put Naldo in ST for jokes or get CB to go on a crazy run?
Here's my team:
How does that midfield work for you? I found when I play 4312 with 3 attack minded CM my midfield gets completely overrun and end up conceding a lot of goals.
To be honest I find it a bit of a challenge, especially coupled with Tactical Defending. Last season's UT I played a Serie A 4-1-2-1-2 with Cambiasso placed in front of Thiago Silva and Chiellini in the middle and Maicon and TOTY Balza either side so not a lot got past :)
As long as I don't give the ball away in silly positions I can go forward and create chances so it's not all bad, I just wanted to try something a bit different this time around (and 4-1-2-1-2 is expensive :(). I was going to get Y. Toure anyway as a rotation player to stick in that central CM spot to shore up the defensive side of things if thigs go pear shaped. Nani is a beast, end of story :D
Javi Carcia could fit nicely into my Barca team replacing Javi Mascherano. :cool:
70 pace
88 defence
85 heading
74 passing
187cm
Spainish
Should get alteast 7 or 8 chem.
