Anyone got any tips for weaponry? Also, is there a reason why I can't select certain perks, even if they're white, not grey?
I'm level 12 with my strongest weapon at only 21 dmg. I get my ass handed to me all the time.
I'm not sure i understood correctly - You are lvl 19 in Smiting and trying to upgrade a weapon or an armour? When you try to upgrade even though it is white (ie active) nothing happens. Is that correct?Nope. I'm only level 19 Smithing, trying to use the first smithing perk and it won't do anything![]()
I'm at the top of the mountain talking to Paarhurnax but only level 13! (Main quest line called Elder Knowledge)
I'm wearing really crappy gear and using a boring warhammer. Any advise on how to spruce the game up a bit?
I would like to start making my own armor, does this mean I have to invest all my points in smithing? How do I actually go about smithing!?
the best way by far to level smiting is by making iron daggers. They only cost 1 leather strip and iron ingot. Then you can enchant that dagger (absorb has pretty high value rating) and flog it to a merchant making mint from it. Use the money to buy more petty soul gems so you can enchant the next one etc, etc. This way you bump up not only smiting but enchanting as well. Good to note is that the size of the soul gem used in enchanting does not have a relation to the amount level you gain per individual enchant.
Thanks mate, is there somewhere in Whitehall that I can enchant on this daggers I just made?
