power draw of 3 way gtx470 sli
14 Apr 2010
swanley,kent
i've just got hold of a third gtx470 to put in sli with my other 2.now is my corsair hx1000 going to be ok to run these on my system in my sig???
With two in an i7 1366 setup im drawing 630w at the wall when gaming. Iirc, Mr may on here is running tri sli 470's on a corsair ax 1200w, (1366 as well) theese older setups are a bit more power hungrier than the new sb's.
Max ive ever hit was 860w, (850w corsair hx). But then i was running prime and furmark at the same time.:D
mind you is that the x2 500W corsair power supply? in which case youll want two cards on one rail and the other card + system on the other rail?
