Yeah, only requires a completely different socket. A socket that seems more geared towards the HTPC crowds.
Not for gamers if you ask me
what isn't gamer about FM1? how can a socket be 'not for gamers?'
what isn't gamer about FM1? how can a socket be 'not for gamers?'![]()
Not talking about the socket, More about the CPUs available on that socket. Who would build a gaming PC around a FM1 socket?
anyone wanting a cheap, highly clockable quad-core (Athlon II X4 FM1 ~£60) on a nice featured micro ATX board running a single graphics card? doesn't sound like such a bad option in that market, its either that or a more expensive I3.
The 960T is near enough the same thing, go buy one and try unlocking it, you might even end up with a sub-£100 hex core processor.
Thanks
What model number was your MSI board?
I think CPU wise I'm good for another year or two. My 6870 always craps out waaayy before my 965BE is even close to its limits..
7950 + 8GB ram is next on my list.![]()
Fixed it for youWe're going to be stuck with the choice between i3 and FX4 at the £100 mark soon, a dual core with HT versus a quad core that performs like a dual core, only when highly overclocked, and when games uses all four cores... no more great value quads.
Not putting that intel muck in my pc. I refuse to buy anything with a "i" in it's name......![]()
It's the same with a competitor to OcUK who shall not be mentioned. Glad I managed to order mine before they got rid of them.
It's still a big step backwards compared to Phenom.
Granted it's a sub-£100 quad core but CPU performance is a lot lower than Phenom (since it's basically a lower clocked Athlon) and the motherboards are quite basic by comparison.
The onboard GPU is the stand out feature of the Llano range, if you're not going to use it then you'd may as well just grab a second hand Athlon/Phenom and 990FX.
Then the Phenom II would probably crap out before your 7950![]()
