i got kicked yesterday for excessive MAV "useage" a rule the admin made up on the fly after i killed him with the MAV a few times.
I really, really need to unlock it.
How do you make the MAV go down?! I only seem to be able to go up and forward back etc....
Really?
Crouch key n0ob.
you will like it, it's funny when you start getting some kills with it and certain guys will single themselve out just to hunt down your MAV's lol. Will take an hour or two i reckon to get use to controlling it. so don't expect to be getting kills with it straight away
Same here, and im dire with it tbh. Cant get the lead on moving targets at all. Even when someone is sat still i have bother hitting them. Longest headshot so far is only 395y/m whatever the game uses to measure.oh god, I've only just unlocked the 2nd rifle with Recon. Something to work on I guess.
I've always thought that.![]()
I use rocket pods on servers with 3d spotting on and guided missiles that don't as I can't see stuff on the ground to shoot otherwise.
With regards to turning in the jet I have found an exploit where if you press the after burner for split second then brake for a split second and keep cycling between them whilst moving the mouse your turns get tighter and tighter until you spin rediclously fast - 360 in about .5 seconds and you can dodge missiles and enemy jets with ease. It is a bit tricky to get the hang of but once you have you can open some whoop ass! As for joystick pilots, lol easy meat!
Nice. Is there a certain map that's best to do this on?
Finally realised who voiced the Russians on BF3!
It was indeed and very enjoyable. Would have been even better if my Engi had repair as well but I was on mines as trying to star up my mines before the patch nerfs them.
