Just to close this off, I performed the upgrade last night by taking the glass off and panel out as suggested by EVH.
Pretty painless. Hardest part is shifting dust from the glass and also the panel before putting it back together.
Im getting iMac with everything on it. Including pegasus drive. Its gonna be a almost 4k machine but it should scream.
Do you have a link to this memory as to get 16gig in an iMac it seems you have to only go via apple. I cant find mac compatible higher volume ram chips
You can get the 4GB chips from here http://www.jigsaw24.com/product-details/m553ata/kingston-4gb-1333mhz-ddr3-sdram-memory-module
Ofc you'll need to buy 4 and scrap the apple chips if you wanna go 16GB...but it'll still be so much cheaper.
I assume this is ok as you don't sell Apple products? If it's not apologies.. just let me know.
Ta.
Hi, tempted to do this to my 2008 24" iMac. Do you have any good links for guides?Finally got round to opening up my iMac and installing my 256GB SSD. Familiar with building PCs but opening up an iMac .... no. But all done, installed and working a treat. Majorly impressed with it, so fast and silent. Superb!![]()
