I want to play it but I think the mrs will get peed off if I out some hours into it.
Can anyone help me with Boethiah's Calling quest?
just want to know who you chose to slay? Don't want to kill Lydia. Should I just go and recruit another house carl?
Not sure if Lydia does that as well.
we have now bought a Wolfdog which helps attack our enemiesproblem is it won't stop barking when I'm creeping about
Yeah I've done that. I killed them all thinking that would be instead of the slaying, but I still have to sacrifice someone. I'm just going to leave Lydia somewhere and go take a follower from another city.You can just go and slay all the people at the camp and then she will assume the body of the last person you kill.
The quest was bugged for me (what a surprise!) and I didn't get the dialogue after sacrificing my follower, so I had to kill them all anyway.
Quick question before i start playing this. KB/M or 360pad?
Don't forget to acquire DO REA MEH, the epic deer shout![]()
Yeh I wish you could force followers to wear what you want them to. I've got Mjoll the Lioness at the moment, she wears the dragonplate armour I gave her, uses the Ebony Battleaxe. But instead of using the Nightingale Bow she uses a normal longbow![]()
The mrs said I'm ok to play it as long as I give her attention. Games installed![]()
I just chose some random follower from one of the inns.
you can i think,
take away everything she's got and give her what you want her to wear? worked for me most of the time![]()
She's got the normal longbow in an invisible inventory. Can't remove it off of her. The rest of the gear is fine though.
Going to be doing that sacrifice quest this evening I imagine, time to get the random bird from the whiterun in to follow me up there![]()
