*** Official OcUK Minecraft Server - Discussion and Rules ***
I'd finally found a few diamond blocks last night! Must have spent a good 90 minutes nearly getting singed by lava trying to find some.
So now is the time to make my first enchanting table. :D
No update.
I would prefer there to be an RB before we start putting extra worlds in place but even without it, the portal will either be implemented in time for xmas or in time for new year.
*fingers crossed for before* Got lots of time off over the xmas period :D Would love access to the 1.7 kit.
What's an RB out of curiousity? :p
Recommended Build. Once Bukkit reaches a point where it is mostly bug free the devs release the RB. Many plugin developers don't bother updating their plugins until an RB is out and some server providers won't let you run a version of Bukkit other than the latest RB.
Just in case anyones interested :)
This is my new build and the square within the walls marked out in torches is the same size as Joachimville from the old map :D
Imagine how cool it would look with it copied over and nicely landscaped in ;);)
Looks like we are Neighbours Joachim!
I am just below you in the Sand (the dug out bit and around), if you need anything or fancy popping around for a tea then give me a shout and I will pop the kettle on :)
Seriously if you need anything or any help let me know
Quick question on mining etiquette:
Say you're tunneling long and straight looking for diamonds and you come across an area where another user has clearly been active, what do you do?
a) Stear well clear of that area.
b) Carefully tunnel round exsisting lit areas, but anything not connecting or not lit is fair game.
c) Carry on going, leaving exposed tunnels and putting cobble where you please. Who cares, all is fair in love and minecraft.
imo depends where it is, if your in the middle of spawn theres always gonna be peeps crossing into each others mines.
If your out in the wilds and come across a lit up mine (assuming its not an abandoned mine) then if it was me id leave it be and dig in the opposite direction etc.
A few times ive come across someones strip mine while digging, generally its easy to tell if your in someones mine by the use of torches, cobble blocking off lava etc.
If in doubt note your location and check the carto see if theres a build nearby, if not id say its fair game again :)
BTW if its freddies its fair game anyway !
this, of OT is just a random mining tunnel, IMO.
Most people's mining are just random tunnels they pay no attention to.
If its clearly engineered like rail tracks or other structures leave alone.
Cool man shall do, all i really need is cobble for stone brick and as you can see I have a surplus of wood :D
Hi, can I get put on the whitelist again, I played on the old old old server.
LinkTart Username: inputpow
MC Username: inputpow
Also can vouch for Hazomg and HipsterBK
