I used to play console...
I would like to see someone trying to play the new Tribes game with a pad. Would give me major lols. Would be kind of like watching people play Quake 3 with a pad. Never before have I seen so much fail.
why?
Well I've recently switched to gaming FPS on a PS3 & I'm having a blast. Yes there was a harsh learning curve but I just stuck at it & am now playing & loving MW3 & am breaking even K/D wise.
If I can switch & adapt at my ripe old age then anybody can, Kicking back on my reclining leather chair & playing MW3 on my 40" flatty with the surround sound blasting out is Awesome.
No more upgrades/system glitches/6 weekly Dust clear outs/sitting up my desk with headphones on/wondering whether a game I just pay 40 quid for will work etc etc etc etc
also console gfx just suck
I played black ops on pc at 1080 high detail then just now try ps3 version.
Its terrible the gfx are really awful compare to a high sepc pc.
I think the only thing that would be better than a mouse to aim in games would be a system that tracks where you look
no way would that have the kind of pin point accuracy required for FPS gaming.
We've been using the mouse to play FPS games since quake. Its not changed a lot since then for a reason.
I think the main reason so many people think joypads are ok for FPS games is that they're only ever using a joypad against other joypad users.
Since when was this a console vs PC thread?
Its a gamepad vs keyboard / mouse thread, both of which can be used on the PC.
Same as you don't need the split second speed unless you play on the very hard settings, but even then the auto aim assist helps massively there too.
As for killzone 3, I played through it using the sharpshooter and playstation move + nav attachments and it was insanely good. Quite hard to get use to the movement, kinda like an arcade machine way of moving with the gun in your hand, yet it really threw me into the game in a way you often don't quite appreciate with a pad. It also allowed the split second aiming of a good mouse if you was fast and skilled enough to use it.
Just a shame its so bloody expensive to buy still though as the move kit was £40, nav controller was £18 and the gun itself was another £35 ontop of that!
I played through KZ3 using the Sharpshooter and it was awesome. I still have to get Resistence 3 so I can use it again. Much better immersion than you get with a pad, and even a pad is more immersive than M&K.
I try and play all my FPS with a pad when playing single player.
List of games on the PC that work better with a 360 controller:
Witcher 2
So when you play FPS games on a PC you plug in a joypad?
Nobody is saying they're impossible to use >.< they're just not as good as a mouse and keyboard
