apologies for the distinct lack of updates - busy weekend with family stuff and busy week at work.
Anyway - latest pictures.
new door fitted - still requires the frame etc to be fitted.
Close up of speaker in place - taken them back out for now whilst I work on the rest of the cabling/flooring/painting etc.
Tomorrow night - will get the other 2 holes cut and sorted. Will aim to get TV bracket up on the wall if possible.
Heading away next week for a few days but hopefully flooring will get fitted monday by joiner (solid oak flooring), painting will be the next thing and then installing all the goodies thereafter!
How deep are your holes for the speakers?
What dimensions was the holes you cut?
I'm doing exactly the same and need some advice....
Overall Dimensions:
(H x W) 423 mm x 270 mm
(16 5/8 inch x 10 5/8 inch)
Overall Depth: 103 mm
(4 1/16 inch)
Cut-Out Dimensions:
(H x W) 387 mm x 234 mm
(15 1/4 inch x 9 3/16 inch)
Holes for the speakers only require a minimum depth of 103mm. However my "false wall" is about 180mm deep.
The speakers also come with a presized cut out cardboard. Stick it to the wall, draw round it, cut it out and they all fitted perfecly 1st time. Very handy and very simple. I just used a proper dry wall hand saw for cutting. About £8 from B&Q.
LCR 280's - info below from their website.
Will potentially have to take the speakers at the front back out and fit them again as they are a bit of a tight fit and when I try to put the grills on them the grills are buckling slightly as they speaker units as very slightly to tightly fitted.
How do you change channel on sky with it in that box?
Just came across this again
Very nice room. Quite jealous!
kd
Superb conversion.
One question though, is there any thing you would change. room design, layout,choice of kit,etc.
Wish I had a garage for similar home cinema.![]()
Booyaka: If it had been my home cinema, only thing I would have done, is to fit a projector lift.
http://www.puretheatre.com/Projectorlift.htm
