Gibbo is just guessing on this onefragile looms.... No.
Yes I am and in utter shock how an injector can cost £500 each
No so, was in Seat today getting my free coil packs for my Leon TFSI and was speaking to the service guy, letters will be going out to PD170 owners who are effected.
Edit: Should also say, I just phoned up my local Seat dealer and mentioned coil packs, he knew what to do and I just went by one afternoon and they changed them, zero hassle.
Load of tosh.
The problem is far worse on the 140 than the 170.
I had mine replaced about 3 months back FOC long before any "recall" - its not actually a recally anyway, its a gesture of goodwill IF you ask, they arent notifying all customers and wont chase then down like a proper recall.
Sorry, thats rubbish.
Its NOT a recall, a recall is when its on the news, when VOSA force the manufacturers to recall every vehicle and track down owners to replace parts with a matter of urgency. This problem has been apparent for nearly 5/6 years and its a goodwill gesture, nothing more and only if you ask from VW.
SEAT might well be sending out letter but they will go to all owners, not just 170 owners as the fault is more common and proliffic in 140's than 170's, also them sending letters isnt a recall, its just good customer service!
I dont have time to bother, its very simple - you are using 1 thread from a skoda forum - have a look at any of the VW forums worldwide, or audi forums, or SEAT forums, the 140 is far more common engine and suffers far greater failure rate. The 170's are in fact mostly common rail, not many PD170's were made by comparison.
The majorite of the internet isnt off the mark, the MAJORITY are driving 140's with failing/failed injectors, not 170's.
If you really dont believe me ring VW!
I'm with Mud on this. I've not heard of a single case of PD140 injector failure and there are multitudes more cars around with that engine than the PD170.
Given that the PD140 is a development of the very reliable old 1.9 and doesn't use the piezo injectors it seems unlikely.
Its a diesel injector working on a rail pressure hundreds times higher than a simple port injection petrol unit. Its not even on the same page in terms of the function of the part.
It certainly appears to be an official recall. There are people on the ukmkiv forum reporting they've received their recall letters in VOSA envelopes. VOSA got involved a little while ago and have been actively trawling forums for people with injector issues to gauge the severity of the problem.
Here's a quote from someone in the Briskoda thread who isn't using blanket terms and is getting down to details:
"It can affect some of the PD140s, but as far as I know the Audi A3 2.0 PD140 (and Golf and Leon 140) uses the same BKD engine as the Octavia which has Bosch solenoid injectors and doesn't suffer from this problem. "
To those who say it doesnt affect 140's
http://www.ukpassats.co.uk/phpbb/viewtopic.php?f=9&t=35154
http://www.ukpassats.co.uk/phpbb/viewtopic.php?f=9&t=42500&p=322032&hilit=injector#p322032
http://www.ukpassats.co.uk/phpbb/viewtopic.php?f=9&t=35389&p=321127&hilit=injector#p321127
http://www.ukpassats.co.uk/phpbb/viewtopic.php?f=9&t=42341&p=320848&hilit=injector#p320848
Hundreds of PD140 owners there with faulty injectors and that took 10 seconds on 1 forum. There are douzens more forums like it full of 140 owners!
